installing springs (pics)
i have been working on my car for about 3 hours now trying to figure out this strut
the top bolt will not come out
the problem is the bolt will not stop spinning
i even tried to loosen it while the strut is mounted up to the car. people said that would hold it but still
no luck. the next way i tried is with the strap wrench.
the nut is so tight i cannot hold the socket still with the strap wrench
i don't have access to air tools so an impact wrench is out of the question although i'm pretty sure that
would just spin the nut as well. does anyone have any suggestions or am i just screwed?
i have been researching and have used the search many times
the allen wrench works fine it's the stupid socket. i can't hold it still with the strap wrench
it's so dang tight or something
what is this strut tool kit?
i will go get one if the sell them at advance auto parts or autozone or napa
about the only places still open
i used a pair of vice grips and clamped down extra tight on the strut shaft but i made sure i was clamped it towards the top by the top plate as much as possible. no problems so far and probably drove about 7,000 miles since installation.
yah if you use an impact gun it will just come off easy as pie.
have you tried possibly putting the strut back on the car uncompress it and then crack the nut a little while the car is sitting on it. That what i had to do with my old cavy, when i was lowering it because i didnt have a air gun...
lol my old spring thread. https://www.cobaltss.net/forums/suspension-67/help-front-springs-78179/
i went thru the same thing. sux... i feel ur pain
yea i compressed the spring until it just flops around on the strut
i'll go to a friend's house and see if i can get it off with his impact wrench
i'll let you know in a little while what happens
