installing springs (pics)
Old Jun 8, 2008 | 03:59 PM
  #51
Smarty Art's Avatar
Are you keeping the socket still and turning the allen wrench.
Old Jun 8, 2008 | 06:36 PM
  #52
massivematt's Avatar
the only way to get it off is using an impact gun to pop it loose. Thats what i had to do anyway.
Old Jun 8, 2008 | 06:40 PM
  #53
jlmd's Avatar
Originally Posted by zackss
i'll go compress the hell out of the spring
see if that helps
thanks for the help so far that was quick
I took mine off with an electric impact wrench...cheap to buy, around $50..took the nut off in literally a second.
Old Jun 8, 2008 | 06:44 PM
  #54
DebadgedBALT77's Avatar
you HAVE to use an impact gun on it to get it off, thats the only thing that spins it hard and fast enough. Trust me. Thats how we do it at the dealership, and how i did it at home. Stop wasteing you time, and just go get an electric impact gun like everyone has been saying, or find someone who has airtools.
Old Jun 8, 2008 | 06:45 PM
  #55
originaladrian's Avatar
well no, its NOT the only way, i did it without an impact. u can do it
Old Jun 8, 2008 | 07:05 PM
  #56
The point is its far more easier to use an impact gun. That bolt is torqued to like 130 lbs or so
Old Jun 8, 2008 | 09:37 PM
  #57
oh no doubt, it was a serious PITA
Old Jun 9, 2008 | 11:32 AM
  #58
Bumpin Balt's Avatar
Originally Posted by philipino guy
i used a pair of vice grips and clamped down extra tight on the strut shaft but i made sure i was clamped it towards the top by the top plate as much as possible. no problems so far and probably drove about 7,000 miles since installation.
I did this also. Works like a champ!
Old Jun 11, 2008 | 06:49 PM
  #59
B-G Suspension's Avatar
if you havent been able to get it off yet.. this is what you do compress the spring a little bit and then hit the nut real quick with the impact.. it should loosen it alittle.. the extra tension with the spring not compressed will help.. then compress it more and zap the nut off..
Old Jun 11, 2008 | 07:11 PM
  #60
Eddie's Avatar
how bout this take both front setups off, go to big o tire or something simlar, pay 20-40 bucks they'll take the stock springs off and put the new springs the shocks. then go home and install everything on the car.
Old Jun 13, 2008 | 02:25 PM
  #61
455rocket's Avatar
Thats what i'll be doing Im not even going to try and fight with that bolt.
Old Jun 13, 2008 | 02:31 PM
  #62
Bolo's Avatar
I took my strut off and then went to a muffler shop and asked the guy to take it off with an heavy duty impact wrench. He did it for free, but I dropped hime 10 bucks for the help.
Check it out!
https://www.cobaltss.net/forums/suspension-67/dropped-my-balt-116897/
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
