Just Lowered my Cobalt....
Old Mar 16, 2013 | 09:10 PM
Lindsayycole's Avatar
Just lowered my cobalt today, 2 in front, 2.25 rear, now my whole car is shaking, and even worse when i hit the brakes, wth? everything is tight, it hugs the road, just shaking, just got new tires, replaced both control arms in the front, new brakes all around, need an alignment. Could that be it?
Old Mar 16, 2013 | 09:21 PM
iToastie's Avatar
Axle bind, and an alignment will help
Old Mar 16, 2013 | 09:23 PM
Wert842's Avatar
Lowered as in? Cut springs, installed coilovers, installed other springs? Need more info...
Old Mar 16, 2013 | 09:26 PM
Sharkey's Avatar
what brand of springs did you use and what model is the car (base, ss/na, ss/sc, ss/tc)
Old Mar 16, 2013 | 09:34 PM
rivaladore's Avatar
Just shaking? Or clunking noises too? Probably didn't tightening something properly or need an alignment. Be more specific like........shakes above 60mph, clunking noise when hitting brakes, etc.......did you drive with these new tires before lowering your car? If no then they probably need to be properly balanced. I hope your lug nuts were torqued.
Old Mar 17, 2013 | 04:40 PM
OK, 2006 cobalt ss not supercharged (waste i know!) Lowered with Lotek lowering springs, shakes at about 20 mph, and about 45 mph, then its fine. No clunking noises, no funny noises just shaking, tires have been on the car for about a month so i have been driving it before we lowered it yesterday. i now know i need to replace my struts, yay. I DO need an alignment im hoping it will knock that shake out, and im going to get the tires rotated also the tread it wearing from the outside in.
Old Mar 17, 2013 | 04:55 PM
rivaladore's Avatar
First things first.....get an alignment. Its hard to help diagnos problems when things that should be done(like alignments) could cause the symptoms
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
