Just a strut question
i went to the shop to get my rims put on but they said my strut was leaking...is this probably because my car is lowered and what kind of replacemnet strut should i get for it...its the front left...im so mad!
you might want to look at the SS/SC or SS/TC shocks. Those could be an option if you want an oem solution as I see you are an SS/NA. Other than that there aren't too many direct fit options. Koni's are an option too but you need to do a bit of cutting.
don't be mad, it's not a big deal. it's fairly likely that if you lower your car, you will have to replace or upgrade your struts at some point.
stockers are cheap as hell, can get one for like 30-40 dollars. or you can go aftermarket. look at some of the vendors here.
x2 and you may want to edit your thread title before a mod gets on you
