Koni Front Strut ??
Koni Front Strut ??
I was thinking, if i ordered some koni's for the front, can i wait till m stockers take a tumble and then insert these? i have to cut and remove stock insert anyway to put koni in, would this work/be ok
thats how theyre designed to be used so i guess yea if you wanna wait till you have to replace them and then cut you could. i just picked up a couple of front struts from a local junk yard off a wrecked balt for $80 and im gonna use those to install the koni's.
They're good. The first Koni struts I did were for a (then new) '75 Corolla SR-5. They worked the same way - cut off the top and gut the stockers, then insert the Konis. Like all Koni's I've had, they were excellent.
The rears work just like older Mustang rears. You have to adjust them by compressing them and turning the shaft.
Good luck with your set-up!
n20saturn
Sep 30, 2015 12:26 AM
