LNF Strut Bar?
#51
Yes I seen the pictures
but the pictures DO NOT PROVE ANYTHING but they do not use a strut bar, which only implies they feel it is not needed, not that it has A NEGATIVE HANDLING EFFECT. there is a big difference between the two.
once AGAIN I ask:
CAN YOU or anyone else PROVE that a strut bar has A NEGATIVE HANDLING EFFECT
once AGAIN I ask:
#52
once AGAIN I ask:
once AGAIN I ask:
I can't fix stupid.
Here's a link to buy one from one of our great supporting vendors, enjoy:
http://www.turbotechracing.com/produ...idproduct=2183
#55
Area, I'll buy yours then. Name, do you have one I can get off of you?
I'm loosing space on my doors so I have to put my stickers somewhere!
#59
#60
I always love it when people resort to calling names.....I didnt call names or even personally attack you, yet you for some reason feel the need to do so to me......
Yes a rear anti-sway bar does have a anegative side effect, it reduces the natural tendency of the Cobalt to be tight/push/understeer and many people cant safely drive a car that is neutrally balanced or slightly tail happy(as the big bar on the market makes a Cobalt) Hows that for an argument for arguments sake.
Yes larger antisway bars improve Cobalt handling, the problem with them is that nobody test them. One company comes out with a 19mm bar, so another comes out with a 22mm bar because its bigger, and yet a third company comes out with the biggest bar, maybe if we all got together and came out with a 35mm bar it would be the best of all of them because its the biggest.
I have a larger front sway on my car, and I am working on a larger rear....so I guess I am at least as knowledgeable as the pro's you talk about.
pro auto x'ers
#61
Not a Sebring
Most car, evens with "highly developed" suspensions and chassis's could benefit from a strut bar.
#62
hehe
hehe
#64
Im getting in on this now, YES a strut bar can improve handling, as long as it is not installed to tight laterally. Can it in any way reduce body roll, absolutelly, if you know how a bar is supposed to work, and you know how suspension works you can figure this out for yourself, if not RTFB!!
Now for the pictures in question regarding a strut bar, that is an epic post in failure!!! First not only does the car not have a strut bar due to the fact it has no mounting points for one because of the adjustabel camber/caster plates installed, but moreover the point is that this car already has a full cage installed which ties all the points of the car together improving handling by stopping body flex, allowing the suspension to fully do its job, funny none of you guys posted that???
Any time a point in the suspension is allowed to move without it being in the design, you are affecting your handling to the negative, and your strut towers do flex as there are thousands of pounds of force on them during hard cornering, this flex DOES NOT ALLOW the suspension to do its job properly as side loads are not part of a strut design. A bar prevents this movement allowing all the suspension force to be transmitted to the strut without the sideloads improving suspension geometry.
On to the point about bolt torque, yes they can snap easy and dont require alot of torque but you are not measuring the shear strength and the bar is there for side loading, when they snap it is not shear but over torque or twist of the stud causing the dammage, the shear strenght is much much higher and the bar does not deal with those forces, just lateral, hence shear.
Do most of these cars need one, NO because they never are driven to realize these extremes. So in that matter they lighten your wallet. However, they can improve the durability and life of your car as well as maintaining your wheel alignment over longer periods of time as they help the strut towers maintain their original positions over time and shitty roads. Its a fact that this deflection in strut towers happens over the years
#65
Maven i said this thread was done, well I certainly am. What a load of c**p...yes our shop built the first 15 Cobalt/Ion race cars with cages. The rules do not permit roll cages past the firewall. We determined that this car based on engineering data and backed up by race testing did not need a strut bar. The Cadillac CTSV did need a strut bar. Look where the struts are, on the 04 -07 CTS V , far from the firewall. And whoever posted that Corvettes did not need a strut bar,well Corvettes dont have struts. As far as I am concerned, along with Alpha Maven et all the strut bar story is an epic fail. Hang your laundry on it
#66
Like Qwik said, the CTS-V.R had braces, it does, triangle ones, AND it uses the engine as a partially stressed member of the suspension
See:
But again youre missing some pretty critical points(and using incorrect terms). First the easiest one to see. If the bar is used to keep the towers from leaning in/out, that means that they are rocking back and forth, the top isnt moving parallel to the ground or the bar, it moves in an arc described by the dstance the top of the tower is away from its solid mounting points. It it moves in an arc, that means its also putting a great deal of tension on the little bolts, like lifting up on one end of the bar slightly as you pull. This can aid quite a bit in causing the bolt to fail beause not only do you have the single shear action of the bar, youve also got tension. And of course youve got the fact that these bars are all installed improperly, if you know there is a single shearing force on a bolt, you never install the part that causes the shear(the bar) on the threaded section.
The biggest point you are inaccurate on, is that bolts are stronger in shear strength than tensile strength. OH, WTF, I though you said they were 1000 times stronger!?!?!? Well, they are, the shear strength(or modulus) is much higher. But shear strength/modulus DOES NOT measure how strong a bolt is when it comes to resisting being cut, like it would be with a shear or a sway bar lateral load. Shear strength measures how strong a material is in resisting being pull apart parallel to is faces/axis, NOT perpendicular to to them, which is what you are talking about. The average garbage 5/16" grade2 bolt has a minimum tensile strength over well over 70ksi(1000's psi), youd be hard pressed to find a 5/16" bolt with a resistance to cutting of even 5ksi. Most are well under 1000psi.
#67
buellfooll
Please stop talking... corvettes don't have struts therefore they do not require a strut bar... Cobalts on the other hand could benifit from one.. the intake gets in the way and maybe the intercooler piping... But the Cobalt is not a highly engineered chasis, it is just different springs, struts, and sways bar along with a few other things, but it is still a cobalt
I hope you don't plan on telling that to the guys at GM Performance after beating almost everything they put the 2008/9 Cobalt SS/TC against at the Nurbergring. This car needs NOTHING!! Only my humble opinion.
#68
GM may have opted out of additional strut support either because it didn't need it or because it sacrificed drivability.. but only they know..
#69
your right, you can't fix YOUR stuipity
because apparently you can't read properly, what I so clearly stated TWICE already.
I WANT PROOF THAT STRUT BARSHAVE A NEGATIVE EFFECT ON HANDLING
(NOT PICTURES OF RACE CARS WITHOUT STRUT BARS)
no one has shown any
YOU have claimed a NEGATIVE EFFECT ON HANDLING and no one, not even yourself has come forward with ANY proof of this. It sure does SUCK being called out on that doesn't it?!
#70
despite the fact that the SS/TC is an excellent piece of GM engineering, the fact remains that it is an economy car and GM most certainly restrained themselves in various areas to make it drivable. If you honestly believe there is no place that it can be improved upon then you are fooling yourself.
I'll stand by my statement. But I hear GM Performance is looking for some new blood. If you think you, or anybody you know, can make this "economy car" any faster around the worlds most famous road racing course there's a good job waiting at GM. As far as the SS/TC being an economy car? The SS/TC is anywhere from $4000 to $9000 more expensive than other trim levels of the Cobalt "economy car". I think a better description of the Cobalt "a reasonably priced race car" that out ran sports cars well over twice the price. Yes, you might improve on this car. At GREAT EXPENSE and lose of everyday drivability. Give credit where credit is due. To the engineers at GM Performance. Not the hackers on this forum.
#71
Come on guys....all you're doing is helping to derail the aftermarket for our cars!!!!! Yes, the aftermarket makes money on these bars. If the aftermarket doesn't make money on the simple parts they sure as heck aren't going to spend engineering dollars on anything else -- it's too risky out there now.
Why did I buy a DC Sports strut bar? Because it looks good and fills in an empty space in the engine compartment!!!! I don't drive my Cobalt hard -- but I want it to look good. I sure as heck don't have the capabilty of making my own special parts so I need the aftermarket to make them.
These posts/threads aren't helping anybody that loves Cobalts! I want the aftermarket to continue to produce parts so I can continue to "personalize" my Cobalt and make it different from everybody else's!
#72
I don't mean to put any aftermarket manufacturers out of business. My point, simply, is put your performance where your mouth is. Now I have to go and watch, with some dismay, Jimmy Johnson win the NASCAR championship. I'd rather see somebody else win but he is still pretty good. See ya!
#74
Right location?
I first tried to secure bar with real strong electrical tape but that didnt hold...
but then i found the perfect location to bolt too...but now my car doesnt start.
#75
