lol installer error?!?!?!
Old Sep 25, 2006 | 05:27 PM
bamfnss's Avatar
so yeah the first picture is of the driver rear spring and the rest are the passenger rear. the shop is called mugsy in york,pa. Pa people don't go there. enjoy the pictures and tell me what you think could possible be wrong with how they are installed.
Old Sep 25, 2006 | 05:29 PM
05BlackCobaltSS's Avatar
for one, they didn't cut the bump stops....
EDIT: What makes you think they installed it wrong?
Old Sep 25, 2006 | 05:32 PM
bamfnss's Avatar
on one side the smaller part of the spring is on the top and on the passenger side the bigger part of the spring is up top
distillion's Avatar
dont need to cut the bump stops.
Old Sep 25, 2006 | 05:36 PM
bamfnss's Avatar
so if i can't miss a bump in the road you hear a nice noise. we had taken it back once today and they claimed they fixed it. we came home and saw this.
Old Sep 25, 2006 | 05:46 PM
Toronto SS's Avatar
I've got the SSC springs and I didnt cut my bump stops, but one spring was def installed upside down.
Old Sep 25, 2006 | 05:48 PM
bamfnss's Avatar
thanks toronto ss for that.
so should i just take it back again tomorrow and be a bitch about it?
Old Sep 25, 2006 | 05:57 PM
Toronto SS's Avatar
I would go back tomorrow and have them look into it.
Old Sep 26, 2006 | 10:24 AM
bamfnss's Avatar
so i called the shop today and they can't take me till tomorrow morning. The guy on the phone told me that the guy who does the springs installs no longer works there. Also they aren't going to charge me anything for it either.
Old Sep 26, 2006 | 10:31 AM
johnkb8's Avatar
good luck with it, but dumb maybe ?, what are bumps stops, and cutting them off or not
Jackalope's Avatar
Its fraking upside down!! Its an easy fix to do at home cause I damn sure would NEVER go back to that shop! Jack up the car, pull the wheel, pull the bolt off the bottom of the shock, the rear will drop down take the spring out and trun it over! Jack the rear back up put the shocks bolt back on install the tire lower the car and your done!
Whole job shouldn't take more then a half hour.
Good luck.
Old Sep 26, 2006 | 10:35 AM
bamfnss's Avatar
jackalope sent you a pm
Old Sep 26, 2006 | 11:10 AM
R33P3R007's Avatar
360 L337 User
look in the picture, see the orange rubber piece sticking down in the middle of the spring thats a bumpstop. gutting it would allow more travel in the spring if you were to hit a big bump. but cutting them or removing them can be a bad idea if the roads suck near you.
Since they do just what they say, they stop the wheel from coming all the way up and breaking anything during big bumps.
Old Sep 26, 2006 | 11:13 AM
Jackalope's Avatar
The first pic you show that side is upside down. The spring should sit flush with the yellow colered rubber pad. Flip that one over and it should fix it.
Old Sep 26, 2006 | 01:42 PM
Halfcent's Avatar
I'm old school
What kind of spring is that? There doesn't look like there is a lot of coil there. My Eibachs have a super-tightly wound coil on the rears with a progressive rate.
Old Sep 26, 2006 | 01:53 PM
bamfnss's Avatar
those are the ssc springs. I had gotten them from zzp.
Old Sep 26, 2006 | 02:43 PM
Halfcent's Avatar
I'm old school
I just checked the SSC web site for some info about these springs. Their own application guide just says "Cobalt". It doesn't even say which one. I have to assume the drop amount they list is for the stock base model, not the SS. In which case, the drop on an SS is less than a half inch up front and nothing in the rear. They keep the same coil rate, which means they have the same amount spring in them as stock. It seems they would basically do nothing for an SS. With the Eibach Pro-kit, you also don't get a real big drop, but at least you get a tighter coil rate and firmer ride.
The SSC spring cost $130 versus Eibach $280. But to spend even $130, plus the install labor, for a spring that doesn't do anything different seems kindda silly.
Old Sep 26, 2006 | 06:41 PM
bamfnss's Avatar
Do a little bit more research...
Rear Before(stock):
Rear After(SSC):
SSC Springs are a great value.
Old Sep 26, 2006 | 06:52 PM
Beck's Avatar
just flip them yourself. as soon as u jack up the rear of the car the back springs literally fall out. take you 5 minutes.
Old Sep 26, 2006 | 07:09 PM
Halfcent's Avatar
I'm old school
Everybody always get so touchy. I fear your pictures show nothing. They are at different angles with different light. Just measure it. And I always do my research. However, I don't wish to start a war.
Old Sep 26, 2006 | 07:12 PM
Beck's Avatar
the pictures obviously show one is installed upsidedown. look at the size of the spring on the drivers side at the top and the size of the spring on the passenger side at the top
Old Sep 26, 2006 | 07:24 PM
denny's Avatar
Halfcent my brother look at my thread
https://www.cobaltss.net/forums/suspension-67/zzp-ssc-springs-27647/
These springs are awesome and they dropped my SS very nicely.
P7X was down here for a meet and his SS is dropped with Sportlines and compared to my SS it's a pretty similar drop.
Old Sep 26, 2006 | 07:39 PM
Halfcent's Avatar
I'm old school
Not the spring pictures, I could see the problem with those. The before/after pictures of the car.
So, from what I'm hearing, the "cobalt" listed in SSC application guide and the associated drop is for a stock SS? That was the part I couldn't be sure of, as I stated.
Old Sep 26, 2006 | 07:49 PM
Beck's Avatar
ah alright gotcha
Old Sep 26, 2006 | 08:03 PM
bamfnss's Avatar
seriously how can you not see a difference?
