lol installer error?!?!?!
Old Sep 26, 2006 | 11:06 PM
Toronto SS's Avatar
Originally Posted by Halfcent
I just checked the SSC web site for some info about these springs. Their own application guide just says "Cobalt". It doesn't even say which one. I have to assume the drop amount they list is for the stock base model, not the SS. In which case, the drop on an SS is less than a half inch up front and nothing in the rear. They keep the same coil rate, which means they have the same amount spring in them as stock. It seems they would basically do nothing for an SS. With the Eibach Pro-kit, you also don't get a real big drop, but at least you get a tighter coil rate and firmer ride.
The SSC spring cost $130 versus Eibach $280. But to spend even $130, plus the install labor, for a spring that doesn't do anything different seems kindda silly.
Before I put the rear SSC springs in I could stick my fist in the rear wheel gap, now I can only fit two fingers. There is an error in your math, they drop the car. 1.5" front and 1.3" in the rear, very similar numbers to the Sportlines.
Old Sep 27, 2006 | 08:13 AM
Jackalope's Avatar
Hmm, looks like about almost a 2 inch drop to me.
Old Sep 27, 2006 | 01:56 PM
bamfnss's Avatar
ok so before we fixed the spring on the driver rear you stick a whole fist under. Switch the spring and only have to angle your hand(flat) to get up under. no more clanking.
Old Oct 2, 2006 | 02:09 AM
Badmunky's Avatar
Looks like a nice drop.
Im thinking of geting the sport lines my self.
But I like the ones you have to.
Do you have a link to where I can get them?
Later
dennis69
Oct 20, 2015 07:39 AM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
