looking for new endlinks
setting them is a pain in the ass.
tighten the top down good and tight {germantorque spec, gudintite} do both sides. leave the bottom of the link loose. put the wheels back on, torque em down {100ftlbs} move the car back and forth a bit to settle the suspension. put the bottom of the end links in the sway bar side. make sure you can move them in and out without much pressure, if any. adjust until you get this. wheels MUST remain 100% straight. tighten them down.
enjoy your new found snappy steering
car has to be on flat ground. a drive on lift will work fine, ramps will not
i didn't pull my amp and sub out. way too much of a pain in the ass to do that. a couple quick corners today with the ss/tc rear shocks on. life is good!
The powergrids are worth it. You dont have to keep replacing them you will notice a slight difference a little quicker feel on turns. They've been on the Koni challenge cars for awhile now as well as qwiks car mavens areas stiners lol but really they are tried and true tested harder than the other replacements.
ls1fbody
How to Guide
25
May 24, 2016 08:10 PM
jasonaudio
12
Jun 16, 2010 01:34 PM
jasonaudio
14
May 5, 2010 02:11 PM
