Loweing problems
Old Apr 9, 2012 | 10:56 AM
Play Pat's Avatar
Loweing problems
I just got lowering springs installed (eibach sportlines) on my stock shocks and struts, and its higher on side on the back. I can't tell if I'm on a slanted hill but what could cause this? It's bothering me. This one a 2009 cobalt lt
Old Apr 9, 2012 | 11:00 AM
Shogokuma's Avatar
drive to a gas station and the platform should be leveled see if its still up on one side there
Old Apr 9, 2012 | 11:38 AM
Sox-Fan's Avatar
Got Brakes?
All Cobalts seem to be a little higher on the passenger side rear.
I hope not. They should be a couple of degrees off level for drainage.
Old Apr 9, 2012 | 12:46 PM
Play Pat's Avatar
Sweet ha thats the side i was talking about, also I needed air in my tires too.
Old Apr 9, 2012 | 01:23 PM
Shogokuma's Avatar
how much difference is it, mine has no difference at all
Old Apr 9, 2012 | 01:24 PM
Play Pat's Avatar
Barely none now, since I fixed my tire pressure. What kind of springs for you have?
Old Apr 9, 2012 | 02:13 PM
Shogokuma's Avatar
SSC, not noticable at least
Old Apr 9, 2012 | 02:18 PM
Shogokuma's Avatar
i am experiencing a vibration at low speeds on the passenger front side tho, most lowered cobalts get that hopefully not you. im in the process of getting a true fix for this issue. some have mentionned rotated transmission mounts
Old Apr 9, 2012 | 03:03 PM
Play Pat's Avatar
Is that a good drop? I see its 2 front 1.5 back.
I thought about getting that, they are good for wheel hop but I dont have the money.
Old Apr 9, 2012 | 09:32 PM
Shogokuma's Avatar
you can always buy them later, im debating between that or trying tht new strut mount i ordered for the passenger side to see if that will cure my problem..
Old Apr 9, 2012 | 10:01 PM
Play Pat's Avatar
I'm saving up for Fe5 shocks and struts for now. Tell me how it works out for you.
Old Apr 9, 2012 | 10:16 PM
ChargedxSSx's Avatar
let them settle
Old Apr 9, 2012 | 10:21 PM
Play Pat's Avatar
Originally Posted by ChargedxSSx
let them settle
I see that you have pacesetter headers, do you like them? I just worry because they are so cheap.
Old Apr 10, 2012 | 05:38 PM
they arent bad ... i dont like the sound they give off tho ... wanna go to a long tube
Old Apr 10, 2012 | 07:11 PM
Shogokuma's Avatar
i have the tc shocks and strust the ride quality is stiffer, make sure you get the new endlinks for the TC and not the SC, they are shorter, and also get the alignment for the tc and not the sc apparently they are different
Old Apr 11, 2012 | 12:20 AM
Play Pat's Avatar
Where did get yours?
Old Apr 11, 2012 | 03:35 PM
Play Pat's Avatar
Im kind of new to this. So what would I need to get?
What else?
Old Apr 11, 2012 | 07:10 PM
Shogokuma's Avatar
endlinks for the TC (if you have the suspension for TC) and springs of your choice then an alignment
make sure they align to the TC specs and not the LJS apparently i learned that most will do the specs of the LT
Old Apr 11, 2012 | 08:12 PM
Play Pat's Avatar
What you mean by the TC specs, sorry just new to this stuff. Where did you purchase more of your stuff? sounds easier just getting coilovers lol
Old May 22, 2012 | 12:47 PM
Shogokuma's Avatar
coil overs are like 1000$ pluss, i paid like 400-500$ at the most, zzp has some kind of junkyard of cobalts i cant remember who i was in contact with but ive been ordering used parts from them i got the entire lnf suspention (struts springs shocks) for like 110 plus 110 shipping since i live in canada.
patooyee
Oct 15, 2015 05:11 PM
importkiller
Sep 30, 2015 07:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
