Lower COntrol Arm bushing came apart
Old Nov 4, 2012 | 07:29 PM
pvee's Avatar
Picture of my Lower Control Arm Bushing failure
LCAdownbushingup2.jpg?t=1352075014
I started hearing some noise right after I replaced brake pads so I first thought a brale pad was loose in the support spring and was ratteling, but I had time tonight to look at it,
How much time would it take me to do each side with the car on jack stands..
Old Nov 4, 2012 | 07:37 PM
Sox-Fan's Avatar
Got Brakes?
It's hard to tell by that picture, but is your lower control arm cracked/broken as well?
Old Nov 4, 2012 | 07:46 PM
pvee's Avatar
I don't think so. It's laying down on the body metal in that Picture.
I can pry the control up and down easily.
Old Nov 4, 2012 | 07:57 PM
K-Train04RL's Avatar
unless you have a press, i dont see you getting them out at home on jack/stands. you can fully replace the control arm though, pretty cheap from ced i belive
Old Nov 4, 2012 | 08:25 PM
Stamina's Avatar
I'd recommend a set of Powell LCABs. They're pretty heavy duty. Just find an auto shop that can press the old ones out and new ones in.
Old Nov 4, 2012 | 09:09 PM
Wangspeed's Avatar
Johns TCABs are meant for the aluminum arms. Depending on the OP budget, I would say just get some new aluminum ones for like 90 each and swap them yourself.
Old Nov 5, 2012 | 12:47 PM
pvee's Avatar
I just completed the left side. The right side was not in that condition so I will do it later.
The hardest part was pressing that new bushing into the control arm.
I finally made a jig by taking two pieces of 2x4 and drilling a one inch hole in each so when it was in the vise it didn't restrict the side that was going toward from moving.
Probably took about 30 attempts before I got it started straight and into there enough I could reposition it without it coming back out.
Before I do the other side I am going to line up a place with a press.
The speed shop I use to work at part time has one, so will probably use it unless I find someone closer.
All the other parts and bushing looked fine, for 65000 miles.
But that bugs me because it is the only car I have ever owned that I had to replace front suspension bushings or other parts under 100K miles.
But I like the car otherwise..
Enough work for an old guy today...!!
Old Nov 5, 2012 | 12:57 PM
Wangspeed's Avatar
A lot of cars today come with a similar bushing design on the front control arms. It works well for quieting the suspension, but they tend to get torn up quickly, like yours. Rather unfortunate if you ask me. Things (usually) get better with non-strut setups.
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Coballin13
Sep 25, 2015 08:43 AM
