lower control arm question
Old Feb 24, 2008 | 11:08 PM
cruisn's Avatar
I have a 2006 Pursuit GT with the 2.4L so it comes with fe3 suspension? crate engine depot has fe5 lower control arms for sale, I was wondering waht the difference is and if they will fit, they look like they will fit. I figure my ball joints are on the way out the door adn you cant get replacement ball joints with out the control arm. thanks for the help
http://www.crateenginedepot.com/stor...P1664C188.aspx
Old Feb 26, 2008 | 12:22 PM
brandon2.2's Avatar
if you look on the crate engine depot site, they have "suspension facts"
I believe the SS and the SS/SC have the same control arms. The site says that the FE1 (LS, LT, LTZ) suspension has steel lower control arms, and the FE3 and FE5 suspensions have alluminum lower control arms.
but I have a question, would there be an advantage to me switching from the steel control arms to the alluminum control arms? I have the base LS, I am doing the whole suspension over, but I figure the steel control arms ought to be stronger, and I am trying to reduce weight, but I dont think going to alluminum control arms will do much.
Old Feb 29, 2008 | 05:05 PM
Maven's Avatar
The FE5 control arms will bolt into any Cobalt or G5 and they are stronger than the steel ones. Theyve also got a stiffer bushing in them so they will change the way a base car rides/handles a bit.
Old Feb 29, 2008 | 05:16 PM
shabodah's Avatar
They bolt into the Ion, too! As do the competition steering knuckles.
Huge improvement in the FE5 arms versus the stamped steel ones. Stamped steel is WEAK.
Old Mar 1, 2008 | 11:39 AM
cruisn's Avatar
I already have the fe3 ones, which are not stamped steel, but maybe the fe5 has better bushings, mine feel a little soft. thanks guys.
Old Mar 6, 2008 | 03:11 PM
qwikredline's Avatar
the wheel base changes slightly with the alloy arms...thats all. Is stronger than the steel worthwhile to do...
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Coballin13
Sep 25, 2015 08:43 AM
