Lowered Car Now Problems
Old Jul 12, 2008 | 07:08 PM
INFE's Avatar
I installed sportlines 2day and now when i turn the steering wheel i hear a clunking noise coming from the frount of the car. Any idea whats wrong???
Old Jul 12, 2008 | 07:15 PM
steddy2112's Avatar
Didn't install them correct
You didn't line up the tabs....
Old Jul 12, 2008 | 07:17 PM
INFE's Avatar
i did line up the tabs.
Old Jul 12, 2008 | 07:18 PM
shutzero's Avatar
is the nut on the top of the strut tightened enough?
Old Jul 12, 2008 | 08:07 PM
stryder's Avatar
x2. my money is on that.
Old Jul 12, 2008 | 08:21 PM
qwikredline's Avatar
like 41 ft lbs....or u missassembled the upper bearing for the spring perch for sure its something you have done wrong....lol
Old Jul 12, 2008 | 08:50 PM
Switt23's Avatar
Mine does it, but i know my strut mount is shot on the passenger side.... and the struts are blown beyond believe... thanks to the local railroad.
Old Jul 12, 2008 | 08:55 PM
eckow8's Avatar
mine makes the same clunking but only at low speeds but I always had it but it just got more noticable after i put my sportlines on. I lined up the tabs and didnt mess with the bearing (as the directions tell you) and I used an impact wrench to tighten the top bolt. I just think it has to do with the problem that GM recognizes but does nothing to fix it...
Old Jul 13, 2008 | 12:24 PM
impact wrenches risk overtightening the top strut nut and you therefore risk collapsing the bearing race in the top strut plate this has nothing to do with GM issues that they do or do not recognize, but everthing to do with poor installation practices USE A TORQUE WRENCH! 41 ft lbs. This is advice you may not want to hear...
Old Jul 13, 2008 | 12:50 PM
INFE's Avatar
yea i used a impact on everything. Damn that a could be my problem
Old Jul 13, 2008 | 12:55 PM
Tazmanian_Dvl's Avatar
did you **** up the strut mount bushings?
Old Jul 13, 2008 | 01:01 PM
INFE's Avatar
thats what it probley is, I really dont feel like taking everything all apart again. Well this sux!!
Old Jul 13, 2008 | 01:03 PM
not to mention the strut mount bushings are expensive if I remember correctly...
Old Jul 15, 2008 | 06:38 PM
BurgesS's Avatar
I have a question? How do you use a torque wrench on that nut without the strut rod turning? I couldn't torque it without it turning and ended up using an impact as well. Now I am thinking I should go back and replace those bearings and redo with torque wrench.
Old Jul 15, 2008 | 07:03 PM
YSUsteven's Avatar
I had a similar problem in stock trim. Traveling at slow speeds, when I would turn the wheel, it would clunk in what sounded like the front suspension. After some research I found that it was the steering shaft. What was happening was that it was binding and then breaking lose, which was making the clunk sound. Took it to my dealer, told them what it was, they replaced it and the clunk was gone.
This may or may not be your problem. It probably would have done it before the install. I am not sure if springs would have any impact on the steering shaft, as I don't know if it physically mounts to the suspension. My guess would be it mounts to the engine or the frame somewhere.
Old Jul 15, 2008 | 07:06 PM
madmark's Avatar
any moron can see that the tabs need to be lined up... my guess is he forgot something or didnt tighten it down enough
Old Jul 16, 2008 | 06:06 PM
INFE's Avatar
everything is tight.. So went to the dealer to see how much those bearings cost and they are $50 a peace lol and i cant return them and it takes a week to order them. So i am going to wait till i take everything apart again and see whats up.
Old Jul 16, 2008 | 07:00 PM
J0NNYBRAV0's Avatar
Can you let me know if you figure out what it is? I'm having the same issue. I'm not sure if it's the bearings or not. Could also be the steering shaft like the other guy said, but I don't know how to check that myself... Thanks
Old Jul 16, 2008 | 07:12 PM
do the intial assembly while the car is in the air then jack it down with cars weight on the strut torque the nut...its not a big torque figure...good luck
Old Jul 19, 2008 | 05:59 PM
INFE's Avatar
well im going to be ripping everthing apart now. I will post my findings for anybody that is having a similer problem.
Well i took it apart and i cant figure out whats wrong. Everything is fine. But when u turn the top of the strut u can feel it poping. So thats my problem but i dont know how to fix it?? Any ideas???
Old Jul 19, 2008 | 07:47 PM
spring compressore then take it apart inspect the bearings replace or grease place the spring coil end in the spring seat properlyline up the tabs and retorque to 41 ft lbs etc...good luck
Old Jul 19, 2008 | 09:27 PM
INFE's Avatar
well i was finaly able to fix the problem! It turns out that i must of got dirt in the bearings some how and the top bolt was alittle too tight. I cleaned and regreased everything and now no more clunking noise
Old Jul 19, 2008 | 10:38 PM
good for you pass the word use a torque wrench! keep it clean....
Old Jul 19, 2008 | 10:57 PM
2fastSS's Avatar
honestly bro that clunking is probably not when your turning... I installed mine correctly but the first time i did it wrong not realizing i didnt cut the bumpstops.... The front is probably bottoming out like crazy causing that clunking noise like mine did and yes its very noticeable
well nevermind see that you found the problem
Old Jul 20, 2008 | 06:50 PM
yes he found the problem but trust me you dont need to cut the bumpstops leave them along i track the car on a fast track and i have not bottomed the car out with sportlines...
Haily229
Sep 17, 2015 07:18 AM
Wind
Sep 11, 2015 06:57 PM
ROADKONE
Sep 9, 2015 02:32 PM
