Lowered cobalt now pulls to one side.
My friend just put some eibach lowering springs on his SS/SC. now it pulls hard to one side. everything has been checked.(tires rotated, aligned, Caster and camber all ok) Is this common? Please help. He got the Sportline Springs.
obviously something is off.... did you get it aligned at a good place? are you sure it really was done right? and on top of that, was it pulling when it was aligned, or shortly after?
^^^ man makes a good point as well
actually they will change with ride height, the lower the car goes the more your toe will be off, the reason i know this is because i had an alignment done when i dropped my car on sportlines it was off, then when i dropped it again on coilovers the toe was off again just worse. the lower i went the more the rear toe was off.
well, coming from a 350z (i would assume from your name) is it always? or are you sure he's just not getting the good ole torque steer?
otherwise sounds like an allignment, but you said you already did that.
Turbo Johnny
Feb 21, 2019 09:41 AM
shawnsseries
Sep 10, 2015 08:29 PM
Josh@ottp
Sep 8, 2015 10:18 AM
