MacPherson Universal Strut Nut Remover
Old Jun 17, 2010 | 12:19 PM
brickloaf's Avatar
I found them online (the specialty tool to get the nut off the upper strut mount) but I'm just wondering if anyone has found a local store they can buy it at? I'd much rather go out and buy it then have it shipped in.
Thanks
Old Jun 17, 2010 | 12:46 PM
LethalSS's Avatar
the one thats made by performance tool? dont waste your money, it doesnt fit.
the socket part is too wide to fit into the opening deep enough (so it barely touches the nut by about 1/4 a millimeter) and they dont give u the right size torx or allen bits.
Old Jun 17, 2010 | 12:57 PM
Illini_06SS's Avatar
22 mm deep impact socket and an impact wrench is all the tools you need.
Old Jun 17, 2010 | 01:19 PM
brickloaf's Avatar
http://www.jcwhitney.com/universal-m.../p2017916.jcwx
that is what I'm talking about, it says it's universal for all macpherson struts and the stock LT struts are macpherson...
Btw i ******* wish I had impact tools but I don't have a compressed air source
Old Jun 17, 2010 | 01:38 PM
Electric ones work just as well.
http://www.google.com/products/catal...d=0CCgQ8wIwAA#
Old Jun 17, 2010 | 01:47 PM
LethalSS's Avatar
really, it wont fit.
the socket is the right size, but its too wide to drop down onto the nut all the way. and like i said before, none of the torx and allen bits fit.
do like the illini guy says, get an impact.
Old Jun 17, 2010 | 04:31 PM
DaBuzzard's Avatar
Truth.
Make sure you break them loose before you jack the car up - the weight of the car on the end of the shaft helps to keep it from spinning.
Don't take them all the way off unless you are using the weight of the car as a "poor mans spring compressor"
Old Jun 17, 2010 | 07:38 PM
brickloaf's Avatar
Damn I need a impact gun... I might just go up to my local shop and bring the stock strut/springs/upper mount anether them to impact off that nut then get them to reimpact the upper strut mount to the new spring/strut assembly (replacing springs and struts
Originally Posted by DaBuzzard
Truth.
is it still possible to easily get it off when the strut is off the car cause I don't really have a choice unless I plan on installing everything in the shops parking lot..
Old Jun 18, 2010 | 02:08 PM
DaBuzzard's Avatar
I always found it easier to break them loose on the car but as long as you have a decent impact, they will break loose pretty easy on the bench.
Old Jun 18, 2010 | 03:20 PM
brickloaf's Avatar
Well I dropped the stuff off q few hours ago, there basically just going to take off the upper strut mounts and put them on the new springs/struts...have to pay 20 per wheel....
Old Jun 19, 2010 | 09:14 AM
css9450's Avatar
I bought that one but had to return it because it was worthless. The socket wasn't deep enough to reach the nut (it has kind of a fat "shoulder" on it that prevents it from fitting) and as was mentioned, none of the shaft fittings were right. I sent it back.
Old Jun 19, 2010 | 10:20 AM
brickloaf's Avatar
Damn well I dropped off my strut/spring assembly at like noon yesturday and there still not ready n
Old Jun 19, 2010 | 01:39 PM
css9450's Avatar
By the way, here's how I did mine: (I meant to post a pic but its too hot to go out to the garage and dig up the specific tools)
I used a 13/16" spark plug socket that has a hex at the top of it. Don't remember which car this was from; it was in the bottom of the tool box. It should fit OK on the big nut.
Get a stubby 6mm 1/4"-drive allen socket and a long 1/4"-drive extension. Put this inside the spark plug socket.
Use a 1/4"-drive ratchet to hold everything while you loosen the spark plug socket (and the nut) with whichever size wrench fits the hex on the socket. I used a 19mm but as old as this thing is, its probably meant for a 3/4".
Piece of cake. If I recall, Halfcent used a regular L-shaped Allen key; that will work too but you need vise grips or something to grip it securely. Using the ratchet helps a lot there.
Old Jun 19, 2010 | 09:11 PM
brickloaf's Avatar
Well I dropped it off like a day and a half ago and still no word from the shop so I'll prob call tomorrow and tell them I'm picking them up at the end of the day if there done or not cause my cars sitting on jackstands and i need my car..
Old Jun 21, 2010 | 01:56 PM
brickloaf's Avatar
Anyone think I could just wrap part the strut shaft in upside down electrical tape then use vice grips to grip the **** out of the shaft then just use some liquid wrench/hammer to loosen it then use a 22mm deep socket to wrench it off?
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
jrocstar
Sep 26, 2015 11:42 PM
