My LS on CA #1's
My LS on CA #1's
I just installed the new CA #1 springs this weekend. I must say I am very impressed by the overall look and feel of the car with them installed. The car rides just a bit rougher than stock and the drop is a nice even drop all around. I am very happy with my decision to go with these. Here are some before and after pics. Just for reference the before pics were taken with my nice camera and after with a cell phone. Also the rims are 17" with low pro tires
DRIVERSIDE BEFORE:
DRIVERSIDE AFTER:
PASSENGER BEFORE:
PASSENGER AFTER
DRIVERSIDE BEFORE:
DRIVERSIDE AFTER:
PASSENGER BEFORE:
PASSENGER AFTER
the drop they claim to be 1.75" front and 2.25" in the rear. I didnt measure it to see how close to this it is, all i care about it that it evened everything out and looks great
You have to get an alignment. With a significant drop you should always get an alignment afterwards even if it doesnt look like you need it. When I dropped mine it was noticeable that the tires were leaning inward.
I don't see why eibach's would break your struts, I mean they are designed for OEM replacement, aren't they? Didn't see anywhere where they required high-performance struts to run the springs.
Originally Posted by NWAE Cobalt
how much??? and can you take a close up of the tire gap??
The springs cost $170 shipped from Cobalt-addictions. I will try and get some close-up later and post them up
They are OEM replacement to the point that they are formed like the OEM springs but they are easier to compress which allows the car to sit lower. It is not required to buy performance struts and springs to install these but you will eventually need to upgrade when the stock parts wear out. The case is with any aftermarket lowering spring you are going to be putting more stress on the stock struts and shocks. With the added stress they are going to wear out faster and need to be replaced eventually. The only option for that is replacing the stock stuff with koni parts.
When i had the alignment on my car it was off only a little. Total toe was off by .38 of a degree and steering was off by like .22 of a degree. Also when your calling around its a good idea to tell them that you lowered it and if you have an underglow kit like i do. Some placed can not accompany for such things with the type of lifts they use.
You should be fine there is a good inch or more of clearance still. The extra height shouldn't be a problem. You could probably fit some 18" wheels and tires in there to fill the gap up completely.
It's not really recommended going a lot different than stock overall diameter.......You can get 15's, 16's, 17's, 18's, etc. all with the same overall diameter.....the sidewall height just changes.
True, however you only have to keep stock diameters if you dont want to have your speedometer reprogrammed. With out reprogramming it your speedometer will not display your actual speed. I think you can take it to the dealership and they can reprogram it if needed.
