My Sportlines are SQUEAKING!
It's been like this for a while now. Mostly on my driver side front spring is where I hear it. Especially when it's cold and also when I put a lot of load on my car when im driving in any of the lower gears. They seem to be working fine but I've just about HAD it with the squeaking I don't know what to do! ANNOYINGGGG...
Anyone ever had this happen?! Any advice?! Please and thank you!
I doubt its your sportline springs sqeaking.. metal doesn't squeak very often (unless its a ford tie rod/ball joint).
More than likely, rubber isolators, control arm bushings, upper strut. etc etc..
Cold weather will make rubber/polyurethane squeak. You can go and lubricate everything and it should help
Damnit of ALL my ******* mods my spring are the ONLY things I didn't do myself. Now I gotta fix someone else's problem... I've never done work with springs to be honest... I have to figure it all out now
But thanks for the advice man.. Appreciated..
Its really not someone else's fault. It happens in the winter, things get cold.. cars don't like cold period... I'm sure if you were driving with your window down you'd probably hear a lot more than just an isolator squeaking..
Anyone ever had this happen?! Any advice?! Please and thank you!the coil kicked slightly out of place and made this noise that made people look at you when your driving down the road like
Alright thanks man! I'm gonna see what I can do to readjust it and lubricate
personally, I'd live with the sound.
but if your really concerned, silicone lubricate should work.. but once you do it once, your gonna have to keep doing it. because dirt and debris will stick to it pretty easy now
Good point. But if you heard the sound.. You'd end up killing yourself if you didnt do something about it.
