My YYZ V.1 for your YYZ V.3/5?
Old Feb 25, 2018 | 11:44 PM
ThePanduuh's Avatar
Hello CSS.net,
I have a full set of YYZ V.1's I'm looking to try and trade for V.5's. I like the handling aspect, hence why I'm sticking with YYZ, but I'd like it to be a little lower since it's not a full on track car.
I know the odds are slim, as I drive the car every day so I'd need yours first or meet local and do the swap (SouthEast PA).
PM if you're interested.
Quoted from another post:
YYZ SPRING summary:
v.1 and all the other variants have the same rising (progressive) spring rate and ride quality. The trim height of v.1 is .25 inches front and .75 inches rear HIGHER than all the other variants The front/rear rake was higher with v.1 to help race track turn-in, drag strip launch, and also help HHR which are 300 lbs heavier in the rear than the Cobalt. We made the v.1 springs at a trim ride height at slightly less than stock TC and folks werent happy, wanted more low. ..
v.2 the spring wire diameter was changed to achieve .25 front and .75 rear LOWER to satisfy the "more low" folks. We had found we didnt need as much rake up at the back with folks using our rear sway bars, so that was good; also the rear coils were made larger at the pigtail to help get the isolators on.
Well, folks complained that the isolator fit was TOO loose at the rear pigtail. SO pigtails were tightened up at the rear on the next run, v.3
v.3 was same as v.2 but, like I just said, the rear pigtail was tightened back up to be snug on the isolator, and the plant manufacturing location changed from Logansport IN to Pokotok MIS; but powdercoating and etching was still done at Logansport. The etcher made a mistake and v.3 was labeled v.4 ( wow its hard to keep this straight!).
V.5 are made in MIS, pc'd and etched in MIS, same as v.3 /v.4, and are heading this week(!) to Illinois where we keep our inventory so purchasers dont get Canadian border costs added in.
thats the summary. Thanks for choosing or considering genuine Powell hardcore raceparts!
Old Feb 26, 2018 | 07:55 AM
jdbaugh1's Avatar
What's the incentive for someone to want to trade straight up for an older, higher ride height version of YYZ springs? You might have better luck if you offer something on top.
Old Feb 26, 2018 | 08:10 AM
cluelessk's Avatar
Seems like a backwards trade...
Old Feb 26, 2018 | 08:14 AM
ThePanduuh's Avatar
for someone who is doing true track driving or drag racing, the added travel by being higher is desired over being low.
Old Feb 26, 2018 | 08:15 AM
ThePanduuh's Avatar
backwards if you don’t want to track your car, but the v.1 is pretty much designed around track and drag use. I know it’s a long shot, but if trading doesn’t work then who’s to say selling will? I’ll probably add cash on top because newer springs...
Old Feb 26, 2018 | 10:08 AM
cw383's Avatar
Interesting info if the older would work better dragging. I would like to see how the axle angles work out on either one (v1 and v3-5) vs stock springs
Old Feb 26, 2018 | 11:03 AM
V7 version coming out soon as well
Old Feb 26, 2018 | 11:08 AM
cluelessk's Avatar
Proof backing these claims up? According to Powell the old springs just sit slightly higher.
BLue NoTe
May 17, 2016 10:06 PM
Powell Race Parts
237
Dec 23, 2012 01:17 PM
09sscalicobalt
Oct 17, 2012 12:56 AM
padlock
Sep 11, 2012 05:57 PM
