Need basic info on LS rims
Old Jul 18, 2018 | 06:25 PM
Blasirl's Avatar
Question Need basic info on LS rims
I am having a heck of a time understanding how to use the search function on the forum. I keep getting way too many unrelated threads, so...
I have a 2007 4dr sedan, I believe you call it an LS. I think the rims are 4x100. They have plastic hub caps. I am not sure of the stock width.
I am looking for information on other stock rims that will fit the car. The rims are 15".
Are there any 16, 17 or 18" stock roms that will fit? If not stock, any low cost alternatives?
Thanks for looking,
Please PM me here: Blasirl and not the forums PM as I am a regular on Cruzetalk.com, but not so much here as this is my daughters vehicle.
Robert
EDIT: I like these, are they stock?
Old Jul 18, 2018 | 07:39 PM
Yes those are stock from an LT
And you are correct, the pattern is 4x100.
Old Jul 19, 2018 | 07:56 AM
jdbaugh1's Avatar
https://www.tirerack.com/wheels/resu...autoModClar=LS
Link above could give you a few ideas of what's available
Old Nov 22, 2018 | 03:38 PM
Blasirl's Avatar
Is there a thread here that shows all the stock rims?
Old Jan 4, 2024 | 05:19 PM
Blasirl's Avatar
Just a quick follow-up: I ended up buying a set of the aluminum rims shown above for my three season tires (Continental Pure Contacts) and replaced one of the stock steel rims so i had a complete set of four and mounted my snow tires (Bridgestone BLIZZAK WS80's) on them.
The reason for the replacement steel rim: https://www.cobaltss.net/forums/driv...stance-327117/
Old Jan 10, 2024 | 06:02 PM
soundjunky's Avatar
I am glad to see you found your answer.
Incase you are still searching for more information (because hte search function DOES suck);
I believe that around 2007 the LT could no longer be ordered with four-bolt wheels;
You will find a MUCH larger selection of available OE wheels if you swap to five-bolt wheels - if my memory serves me, this is essentially only a hub and rotor swap.
The LS is the absolute 'base' model;
I believe that LS models typically had crank windows, and power-nothing;
The LT model came with power (just about) everything - and was the model package sandwiched in between the LS & SS.
If you have any specific 2007 model year query, I have collected factory brochures, and could get you probably about any info you might need.
Old Jan 11, 2024 | 12:09 PM
Blasirl's Avatar
Thanks for the reply. I mistakenly said I have an LS, but it is an LT and is also a 2007 with 4 bolt rims. Unfortunately the edit function is severely limited for me on this forum. I am interested in any factory brochures for the 2007 LT. Do you have them on the forum somewhere?
Old Jan 11, 2024 | 02:59 PM
soundjunky's Avatar
The brochures are not trim level specific.
Here is one on eBay right now: LINK
lobalt2.2
Mar 10, 2013 02:54 PM
ECaulk
Oct 3, 2010 09:08 PM
Ecotecrocks611
Jan 3, 2008 04:17 PM
DallasCobalt
Jun 7, 2007 07:32 PM
RedBaseBolt
Jul 23, 2006 12:41 PM
