need help from a bagged balt
without giving away too much of my balts makeover i need to know from somone with a balt on airbags.... how did u cut/grind down the rear bottem nipples so the bags sit flat.... i cut it with a cutoff wheel and need to grind it flat now somehow
You should be able to grind it smooth with your cutoff wheel. You could cut a nice round disk from 1/8'" flat steel (from the Ace hardware) and put in the spring pocket so you have a smooth surface for the airbag to sit on.
I saw a S10 (I think) at the Milwaukee car show on Saturday. It was on airbags and was sitting on the rocker panels! You going that low?
Dennis
Dennis
Dennis
Dennis
roth
Sep 26, 2015 12:16 PM
