need help fast!
well i took the rings off and it did nothing for me. i then came up with the idea of getting them turned. its cheap, only $10 per rotor, but the midas guys said that chevy would prolly fix it for free since its under the warranty so i am going up there tuesday to check it out.
Are you kidding, that's all mine took to be perfect...hmm...did you pull them off the backs also? They're on all 4 corners, just in case you didn't notice. On the wheels I got the center caps were pushing the hubcentrics out too far so I took them to work and milled a little off the back, try that. I never ran them when they were pushing out the hubcentrics but that could be the problem, maybe it's not seating even or something.
Originally Posted by rbowers403
because aftermarket weels can be heavier which will make the brakes work harder to stop the car which will create heat and warp the rotors. i would seriously take them off!
If you came to my dealer with aftermarket wheels on I'd charge you, in a heart beat. Also the "rings" you removed if you have them put them back on when you put the stock wheels on. If you come in asking about warped rotors and the rings are missing the tech says ok this guys had his rotors off the car. Your dealer may not give you a problem but there is always the chance.
Originally Posted by victory_red_SS
If your going to work on your car you will want to buy a torque wrench.
