need help on strut choices
Old Mar 15, 2011 | 11:02 AM
miltowncobalt's Avatar
Well put on my h And r springs and my struts are really bad and I was looking at the kybs cause of the price. But what would you reccomend for struts for a decent price. Or what do u think about kyb
Old Mar 15, 2011 | 11:57 AM
Hammbones's Avatar
What type of SS are you running?
LS/LT run the FE1 shocks struts
SS/NA (Sport) runs the FE3 shocks/struts
SS/TC - SC run th FE5 shock struts.
I've heard if you're not trying to go aftermarket with the ride quality, upgrading from anything to the FE5 for stock ride quality. I ordered SSC springs and when my FE3's go out, I'm reordering the FE5 from CrateEngine Depot. Once I do that, Ill be upgrading from gms0 to gms1 and eventually into gms2 when I boost it.
That's what I take from the people on here helping me with selecting my suspension upgrades.
Old Mar 15, 2011 | 12:18 PM
I got the 06 SS s/c so what strut do you think the f35?
Old Mar 15, 2011 | 12:29 PM
TurboTechRacing's Avatar
KYB are the OEM replacements at best (GR-2's)
KONI will be an upgrade.
Old Mar 15, 2011 | 12:31 PM
07BoostedG5's Avatar
fe5 (turbo model)
Old Mar 15, 2011 | 12:34 PM
Well which one would be the best ride quality on h and rs
Old Mar 15, 2011 | 12:36 PM
FE5 are good, but are just not adjustable like the Koni's
Old Mar 15, 2011 | 12:41 PM
My honest opinion I would not put any drop spring on any of our struts other then pedders, Now I will get others who disagree, but when you put a spring, especially a drastic dropspring like sportlines for example, your putting your strut under stress/load since it was not made for it, thus killing the strut sooner as well as the strut mount(ask me how I know ). I dont know anything about the koni's but why not spend the money once, get the fe5s with pedders or fe5 springs.....just my 2cents.
Old Mar 15, 2011 | 04:23 PM
Does anyone know how much the fe5's are?
Old Mar 15, 2011 | 04:33 PM
ssyellow's Avatar
$300 from CED with rear shocks
Old Mar 15, 2011 | 04:47 PM
CruzinYellow's Avatar
I just recently bought an FE5 (strut) set from CrateEngineDepot.com for around 195.00 shipped and put FE5 springs (bought used in like new condition from another member for $60 shipped) on as well.
07BoostedG5 made a good point that most people fail to think about or even realize. If you put lowering springs on struts that are specifically designed to work at stock height, you are essentially damaging your struts and they will wear out quickly. I had the Eibach Pro-Kit Springs (installed and only used for around 20,000 miles mostly highway) but they don't lower an SS near as much as the Eibach Sportline set does. Anyways I had my original set of front struts last me till around 68000 miles so regardless I would have more than likely been changing the struts soon anyways had I changed springs or not. If I had used springs like the Eibach Sportline set I would have needed struts sooner than I did. Like I first mentioned, our struts have a certain operating range. When you drastically change the height of your car, you are taking them out of that range which damages them quicker.
I would suggest you use the KYB struts simply because they are adjustable if I'm not mistaken.
Old Mar 15, 2011 | 11:31 PM
the kyb's arent adjustable, i dont think
Old Mar 17, 2011 | 06:21 AM
Your right, kyb's aren't adjustable. I was thinking of the Koni Yellows that are adjustable. My fault...
Old Mar 18, 2011 | 02:18 AM
Phil424's Avatar
KYB is the best.
Old Mar 18, 2011 | 05:19 AM
quikdcride's Avatar
what is adjustable about the konis?
the height or the dampening?
Old Mar 18, 2011 | 08:22 AM
Fidget's Avatar
Just dampening.
I went with the Sportline / Koni combo and my koni's didnt last that long. i have about 90,000 miles on them and they are done. If i was to do it again (which is going to happen shortly) Ill be going with the Pedder / FE5 setup.
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
jas09ss
Sep 26, 2015 01:06 PM
