Need PN/source for rear brake banjo bolt washers
Old Jul 20, 2019 | 10:04 PM
colodude18's Avatar
So it appears that my driver's side rear brake caliper is seized
I can't turn/open the cylinder far enough for the new pads to fit.
I already ordered a new caliper but Powell tells me the banjo bolt washers may be harder to find.
Does anyone have a part number and/or source? Thanks!
Old Jul 22, 2019 | 12:24 AM
cobaltss#01's Avatar
I believe I got mine from Tom @CrateEngineDepot and I know I got extra ones but I'll be damned if I know where they're at.
Old Jul 22, 2019 | 08:35 AM
jdbaugh1's Avatar
Are you talking about the copper crush washers? If so I would just measure it and get a kit like this that has something close in it.
Amazon Amazon
I use these all the time on various applications. Even if you don't have the exact original size as long as you can get the washer centered and it is sandwiched in between the mating surfaces it will work just fine.
Old Jul 22, 2019 | 09:31 AM
Kolt's Avatar
Acdelco 24430175 is the factory number but like jdbaugh said, you can measure the copper washer and buy close to the same size and itl work.
Old Jul 22, 2019 | 10:45 AM
colodude18's Avatar
Thanks guys! I remember that when my shop installed the SS brake lines there were issues with leakage which is why I was concerned.
Old Jul 22, 2019 | 10:52 AM
jdbaugh1's Avatar
I one time bent a banjo bolt (don't ask how) but that was the only time I have ever had any issues with them leaking. I keep copper crush washers around because they are cheap and I like to use fresh ones any time I remove a banjo bolt. Main thing is ensure the mating surfaces are clean.
Old Jul 22, 2019 | 10:58 AM
Kolt's Avatar
I have just learned that gm has discontinued those washers so it may be hard to find. If you do get a factory one get the measurements before installation so I can do some research and find alternatives for the future.
SilverSS2008
14
Jan 28, 2012 03:36 PM
strykr
Aug 17, 2011 08:38 PM
jmdubose202
Aug 8, 2010 12:50 PM
mkulrey13
May 1, 2009 01:01 PM
qwikredline
Mar 21, 2008 07:24 PM
