Need suspension help..
Old Oct 30, 2016 | 04:00 PM
BigMajin's Avatar
What's the cheapest option besides junkyard to get the oem parts needed the dealer quoted for suspension? The dealer charging over 2k in parts and labor.
Old Oct 30, 2016 | 04:42 PM
Sharkey's Avatar
i would take it to an independent shop to have it looked at, dont tell them you had it elsewhere for an estimate already.
i can take some guesses from the list
-front control arms- gm services them as an assembly, id take a wild guess and say its just the rear bushings that are bad. Moog makes rear bushings, there are also options for performance bushings (powell motorsports)
-shocks and struts- likely just worn out. you can order the ss turbo struts from crateenginedepot.com, thats your best bet for a quality replacement
-outer tie rods- likely just have play, moog will be a quality replacement
-wheel hub- bearing likely has play, skf bearings/hubs are a good replacement.
you dont need to put oem parts in the car, there are quality parts in the aftermarket for these cars. if you insist on oem, use Crate Engine Depot - Chevrolet Performance Parts and Engines, they are a gm dealer and sell oem stuff at good prices.
Old Oct 30, 2016 | 04:47 PM
BigMajin's Avatar
Thank you sir.
Old Oct 31, 2016 | 03:16 AM
Stumpalump's Avatar
Go to O'reily auto parts.
Old Oct 31, 2016 | 06:10 AM
63 Nova SS's Avatar
Sharkey has some good advice here. How many miles are on the car? Are you planning on keeping it for awhile, and what kind of funds do you have available?
Old Oct 31, 2016 | 10:11 AM
BigMajin's Avatar
135000 miles keeping car. Going TVS.
Old Nov 7, 2016 | 09:37 AM
rntbuck's Avatar
im kind of in the same situation, i just bought an 07 balt, and i want to go back to stock/stock type springs and struts, as the previous owner has the car lowered, and i don't want that. contemplating going to the junkyard, or wondering if there is a better alternative. On this, i do not want to break the bank. Im going to assume the struts and springs on eBay aint no good?
Old Nov 7, 2016 | 10:01 AM
Supercharged06SS's Avatar
Check out amazon for FE5 struts and shocks. https://www.amazon.com/ACDelco-506-683-Original-Equipment-Suspension/dp/B001SGYDK8
Old Nov 8, 2016 | 10:00 AM
rntbuck's Avatar
not bad... wonder if these are worth a hoot?https://www.amazon.com/Front-Passeng...RG9VA2Z2J7NJZ5
Old Nov 9, 2016 | 04:32 PM
Those are gonna have you at the height of a basemodel pretty sure. Id just go with the oem fe5 struts and shocks if you can afford it
Old Nov 9, 2016 | 04:37 PM
rntbuck's Avatar
right on... I'm gonna look into it, i may not want to put that much into those springs and struts, just for a car thats pretty much going to be torn up. we are gutting it and building a dirt car out of it. thanks very much for your help. and thanks for helping out a new balt guy
Old Nov 9, 2016 | 04:51 PM
Ohh gotcha in that case you probably dont care about the height of the car. Those should work fine. And no problem
Old Nov 9, 2016 | 04:53 PM
rntbuck's Avatar
yes and no.. thats kinda the problem now... the car is too low with squishy suspension allowing the car to bang the ground pretty easy. 200 laps on the track with that would tear the car up. I'm actually trying to get a little suspension and travel under it
Old Nov 14, 2016 | 11:06 AM
rntbuck's Avatar
bingo... got me a full fe5 set on the way. that should take care of that.
