Need Sway bar end link tourqe specs
I need the sway bar end link tourqe specs. Im changing my struts and Im putting them back on but i need the tourqe specs to tighting the bolts. Please help right now, Im stranded without the info. Thank you.
Haz l33t wheelz.
Specification
Metric
English
Ball Joint to Control Arm Nut and Bolts
68 N·m
50 lb ft
Ball Joint to Steering Knuckle Nut
First Pass
50 N·m
Reverse Nut 3/4 turn
37 lb ft
Second Pass
50 N·m + 30°
37 lb ft +30°
Control Arm to Front Frame Bolts
55 N·m
41 lb ft
Control Arm to Rear Frame Bolts
100 N·m + 180°
74 lb ft +180°
Frame to Chassis Bolts
100 N·m + 180°
74 lb ft +180°
Intermediate Shaft Pinch Bolt
34 N·m
25 lb ft
Stabilizer Link to Strut Nut
65 N·m
48 lb ft
Stabilizer Shaft Clamp Bolt
50 N·m
37 lb ft
Stabilizer Shaft Link to Stabilizer Bar Nut
80 N·m
59 lb ft
Strut Assembly to Steering Knuckle Nut
120 N·m
89 lb ft
Strut to Body Nut
20 N·m
15 lb ft
Strut Shaft Nut
70 N·m
52 lb ft
Transmission Mount Through Bolt
100 N·m
74 lb ft
Transmission Mount to Frame Bolt
50 N·m
37 lb ft
Wheel Bearing/Hub Assembly Mounting Bolts
115 N·m
85 lb ft
Metric
English
68 N·m
50 lb ft
First Pass
50 N·m
37 lb ft
Second Pass
50 N·m + 30°
37 lb ft +30°
55 N·m
41 lb ft
100 N·m + 180°
74 lb ft +180°
100 N·m + 180°
74 lb ft +180°
34 N·m
25 lb ft
65 N·m
48 lb ft
50 N·m
37 lb ft
80 N·m
59 lb ft
120 N·m
89 lb ft
Strut to Body Nut
20 N·m
15 lb ft
Strut Shaft Nut
70 N·m
52 lb ft
100 N·m
74 lb ft
50 N·m
37 lb ft
115 N·m
85 lb ft
thanks ls1!!!
got it done, and all is torqued to spec.. i tried searching but theres so many pages of BS then the site runs slow its impossible
graci!
graci!
DANRICKARD
10-01-2015 12:08 AM
