New Design Moog Control Arm Bushings
Old 09-22-2014, 07:10 AM
Administrator
Administrator
Staged07SS's Avatar
Cabs arent hard to install.
Just remember to put the new cabs in the freezer for a few hours. Do this, and they will press in like butter!
Old 09-22-2014, 08:21 AM
That didnt help me at all and we were at a shop with a press and other great tools
Old 09-22-2014, 08:22 AM
Administrator
Administrator
Staged07SS's Avatar
Newb.
Old 09-22-2014, 08:43 AM
blueLNFftw's Avatar
Newb.
Owned.
Old 09-22-2014, 01:47 PM
toolman's Avatar
Originally Posted by YelCal7
I don't mind doing it cause I've done it many times. I had tried Powell's and his is the best 1. I have OTTP CAB in right now and the rubber piece has split open and making clunk noise if I am on really bumpy roads. I am willing to try Moog new design CAB, it doesn't hurt to try them out. Then I will know how long they last, Powell CAB last 2 1/2 years no problems, OTTP CAB only last 1 year but I will have it replace since OTTP said life time warranty. Now I am gonna try MOOG new design CAB and see how long will it last.
What happened to Powell's? Why aren't you still using them?
Old 09-22-2014, 01:55 PM
YelCal7's Avatar
I had Powell's on my other Cobalt and traded them in to Cruze. BIGGEST MISTAKE that I had ever made. Then got rid of Cruze got Cobalt back last year. I am starting all over, I will get Moog new design CAB and when I have enough money then I am getting Powell's as back up if Moog fail.
Old 09-22-2014, 01:59 PM
cobaltss#01's Avatar
so did the powell cab go bad or you don't know cause you traded the car?
Old 09-22-2014, 02:02 PM
YelCal7's Avatar
No way! Powell's don't go bad at all for 2 1/2 years before I traded in to Cruze. I was looking for better mpg but I was wrong. HELL! I was devastated.
Old 09-22-2014, 02:05 PM
Josh@ottp's Avatar
We started shipping the new cabs in January of this year. We have sold 44 sets since then with no complaints but yours. This doesn't make them bad parts. I still haven't seen your parts so I don't know if they are bad. When we talked you were having multiple problems with your suspension if I remember correctly, alignment was changing and I think your rear cradle bolt was stripped or kept coming loose? Without proper diagnosis it's impossible to know if it is the joint that is even bad. A boot tearing could be a defect or could be installer error, it doesn't make the joint make a clunk noise though.
Old 09-22-2014, 02:10 PM
Powell Race Parts's Avatar
The moog are similar to mine a lot heavier as they have a large steel shell the principle of operation is the same. The rubber seals are rubber on mine plastic or hard shell on the moog. The centre ball joint is thicker wall and higher grade steel to a much better finish on mine and the bearing shell is nicer on mine but the moog has a lot more grease in it and the bearing is slotted to deal that. I have never had to replace any of mine we have been using them for ten years. The race pure monoball open joint spherical ones we made last about a month or two.. .
Old 09-22-2014, 02:18 PM
  #36
I am sure a 140 dollar price point difference will certainly have folks re think what they buy.
Old 09-22-2014, 02:36 PM
  #37
umrdyldo's Avatar
So did we find a part number for the FE5 Moog part?
Old 09-22-2014, 02:55 PM
  #38
YelCal7's Avatar
I will post up pictures when I take them out possibly today. I had no problems installing it in my car and off of my car. I had torque them 145 tq ft pounds.
I had no problems with my suspension at all either from what I had checked.
Old 09-22-2014, 05:19 PM
  #39
Spawne32's Avatar
Originally Posted by umrdyldo
so did we find a part number for the fe5 moog part?
k200792
Old 09-22-2014, 08:05 PM
  #40
umrdyldo's Avatar
Originally Posted by Spawne32
k200792
So why do all sites say for FE1?
Old 09-22-2014, 08:45 PM
  #41
Spawne32's Avatar
Some sort of misprint, the moog catalog on the moog website lists it as FE3/FE5. FE1 replacement bushings are rubber.
Old 09-22-2014, 09:31 PM
  #42
LNFTX's Avatar
Im not lazy I looked as well and seen fe1 could you post a link
Old 09-23-2014, 12:51 PM
  #43
toolman's Avatar
I think the Moog bushing uses a rubber seal. It's flexible to allow for the control arm to move as intended.
Moog MOOG BUSHINGS & BUSH K200792: Advance Auto Parts
They are sold individually, so you'll need to order two if you go this route.
Old 09-23-2014, 01:01 PM
  #44
exninja's Avatar
It looks like it's not a mistake. Someone in this thread: www.g5club.net Moog-K200792-vertical-bushing-on-FE3-lower-control-arms asked Moog about it and the response was that it's not for the aluminum arms. Similarly to the other thread, I'm not sure what they're worried about but it looks like their solution to the FE3/FE5 isn't ready for prime time just yet. I guess it's "use at your own risk" until then.
EDIT: Looks like Toolman is involved in that other thread as well
Old 09-23-2014, 01:24 PM
  #45
YelCal7's Avatar
Meh! What's the difference of you get regular bushing and it still have steel outter ring around with rubber bushings.
Old 09-23-2014, 01:45 PM
  #46
exninja's Avatar
No clue...
Old 09-23-2014, 02:17 PM
  #47
Josh@ottp's Avatar
the press fit is different for aluminum and steel arms. That's the difference.
Old 09-23-2014, 02:39 PM
  #48
Spawne32's Avatar
size of the outside ring i would assume, i dont know whats going on with the part # mixup, advance has it listed for SS but its showing RPO code FE1 lol moog's website the other day said FE5 but now it lists it as FE1 for both style bushings, rubber and spherical. Then there's this post.
Moog K200792 vertical bushing on FE3 lower control arms?
Old 09-23-2014, 02:53 PM
  #49
toolman's Avatar
Of course, but if you search for parts for a Pontiac G5 GT, these come up (PN K200792) as being an exact fit. I used these, and they are an exact fit for the FE3/FE5 aluminum control arms. If you search for a Cobalt, they are listed as FE1 only. I believe they are mislabled, because these are not going to fit in the FE1 steel control arms even though they are listed for that purpose.
Old 09-23-2014, 03:44 PM
  #50
YelCal7's Avatar
Got OTTP CAB out. Yeah, It's really bad. Rubber boot split opened and rusted inside the joint. I tried upload the pictures but my frickin IPhone won't let me due to IOS 8 glitches. Josh aka OTTP has the pictures that I send it to him.
Quick Reply: New Design Moog Control Arm Bushings
