new struts what else do I need?
Old Mar 21, 2014 | 10:08 PM
LNFTX's Avatar
Buildmeanempire showed me a great deal on shocks and struts but what else i I need to replace up front with the struts? i would like to order it and have it on hand.I know there is a rubber boot up top and a plastic spring seat at the bottom that usually go bad but what else? Ced sells a strut mount and bearing kit but does that come with the tc bearing and does the mount actually g bad or just the bearing? And hopefully last will I need an alignment after im not going lower
Old Mar 21, 2014 | 10:27 PM
buildmeanempire's Avatar
I had to change a mount cause two bolts came loose but that's probably just him or miss and not required usually. Only thing I would specifically recommend would be end links if you haven't done them yet. Not to mention that you'll probably have to replace them since they're a bitch to take off without destroying them.
Old Mar 21, 2014 | 10:32 PM
Get some Moog Endlinks for sure.
Old Mar 21, 2014 | 11:17 PM
BlackielawlessSS's Avatar
moog is good shiz. If you need a cheap hook up on moog lmk fellow texan.
Old Mar 21, 2014 | 11:26 PM
LNFTX's Avatar
My moog endlinks shipped out today ordered them a few days ago good to go there thanks
Old Mar 28, 2014 | 11:36 AM
05g5's Avatar
In for more info bout the bearing kit.
My suspension needs fixing come summer, or once the roads clear up
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
ROADKONE
Sep 9, 2015 02:32 PM
