Official Koni Club
Old Apr 8, 2008 | 04:31 PM
Dunkinuts's Avatar
Exclamation Official Koni Club
Ok since they are at my door waiting for my to come home. I think we should start up a club to talk about settings, pros, cons, suggestions for set ups, etc. I will also be making a sig marker for club members (you must show them with/installed the car to get in.)
Koni Club Members
1. Dunkinuts
2. Brandon97Z
3. Cobalt30
4. Fallen33
5. CARLYLE
6. gRuNg3b0y
7. sherm420
8. 07MetallicSC
9. eazyasone23
10. Fidget
11. 395 plus
___________________________________
Adjustment Process
FRONT
Rebound Adjustment Procedures
Externally Adjustable. These dampers can be adjusted, literally at the turn of a knob, a technique borrowed from Formula-1 racing where KONI dampers have dominated the field for years. One can switch back and forth, in most cases in a matter of seconds, from a comfortable "touring" setting to a more firmer setting for a sporty drive. By means of a knob damping forces can be altered to driving conditions or personal preferences.
REBOUND ADJUSTMENT DIRECTION
Clockwise = Softer
Counter Clockwise = Firmer
REAR
Remove the shock absorber from the vehicle and hold it vertically with the lower eye or pin attached in a vise. Use clamp plates to prevent damage.
Fully collapse the shock absorber, at the same time turning the dust cap or piston rod slowly to the left (counterclockwise), until it is felt that the cams of the adjustment nut engage in the recesses of the foot valve assembly.
The damper may have already been adjusted. Therefore check whether the shock absorber is in the adjustment position or not by keeping it collapsed and gently turning it further to the left counting at the same time the half turns until a stop is felt. Stop turning then and do not use force.
Keeping the shock absorber collapsed, make 1 half turn (180 degrees) to the right (clockwise). In case of prior adjustment add the number of half the turns previously found. The total range is about 5 half turns.
Pull the shock absorber out vertically without turning for at least 1 cm to disengage the adjusting mechanism. The dust cap or piston rod may now be turned freely.
ADJUSTING DIRECTION
Clockwise = Firmer
Counter Clockwise = Softer
Old Apr 8, 2008 | 04:32 PM
Cobalt30's Avatar
Too lazy to take pics but im in the club lol
Old Apr 8, 2008 | 06:05 PM
Brandon97Z's Avatar
I guess i was the first member
Old Apr 8, 2008 | 06:35 PM
Dunkinuts's Avatar
^^^ sweet pictures
what settings do you have them on? how long have you had them
well i made it so i am first you are second
Old Apr 8, 2008 | 07:22 PM
Cobalt30's Avatar
your lucky konis are bad ass and i love em. other wise i woudlnt of uploaded this one pic just to join haha
now add me as official.... suckers
Old Apr 8, 2008 | 07:32 PM
Brandon97Z's Avatar
Originally Posted by Dunkinuts
^^^ sweet pictures
I was the test car when these were designed , i don;t even have a production set. I usually just leave them on full soft but will turn the fronts to full firm and the rears to 3/4firm when i get an ich to go drive up the twisties. Set the rears to full firm and fronts to full soft at the drag strip.
Old Apr 8, 2008 | 07:52 PM
Dunkinuts's Avatar
awesome. do you happen to know what they are when they come? i am thinking of putting them full soft and if i like the handling then keep it. but not hard is it to change them. I know the fronts are easy but that backs you have to remove don't you?
Old Apr 9, 2008 | 04:11 PM
Dunkinuts's Avatar
only three people have konis?
Old Apr 9, 2008 | 04:45 PM
Cobalt30's Avatar
only 3 people are big enough dorks to wanna be in a Koni club lol
Old Apr 9, 2008 | 04:51 PM
joeyblaze's Avatar
wait am i slow but i thought they didnt make shocks ment for lowering springs for our cars. are these brand new, i have G5-GT same as SS/NA would these work>? please give a link....
ARE THESE THE ONES U HAVE CUT OPEN THE FRONT STRUT OR SOMETHING?
how hard is that sorry for caps
Old Apr 9, 2008 | 05:10 PM
Switt23's Avatar
These have been around a year or so...
The shafts are shortened to reduce the "bottoming out" factor and are revalved basically for the lowered car. You do have to cut up the stock front struts, but once you put a set of koni's on, you'll never want to go back to stock.
Old Apr 9, 2008 | 05:59 PM
Brandon97Z's Avatar
Not sure what setting they come as when shipped as koni had them installed when i picked my car up. The rears are easy to do, just not as easy as the fronts. There's two bolts that hold the rear shock on, one on top one on the botom. Remove those pull the shock out and compress it all the way down. To frim them up i think you twist it clockwise and counter-clockwise to soften them up (that could be switched up you should have directions with them that tell you which way is which).
Old Apr 9, 2008 | 06:01 PM
Cobalt30's Avatar
Thats because you cant go back to stock
Old Apr 9, 2008 | 06:05 PM
CobaltSS 16's Avatar
Looks like people love them. I think if I were to upgrade my struts, for a little more, I would get coilovers though.
Old Apr 9, 2008 | 07:18 PM
blk_cobalt's Avatar
I'm getting mine installed tomorrow!!!!!!!!!!
Old Apr 9, 2008 | 07:22 PM
idunn's Avatar
how much do these run? and what springs are you all on?
Old Apr 9, 2008 | 07:59 PM
Dunkinuts's Avatar
i spent right around 900 shipped for konis at all four fours and H&R race springs.
get pic and you can join the club
Old Apr 9, 2008 | 10:47 PM
Cobalt30's Avatar
doing it yourself? Its not a bad time. I did mine today with no assistance from anybody. Its just time consuming but still not even that bad.
Old Apr 10, 2008 | 01:32 AM
Brandon97Z's Avatar
konis=freee
Old Apr 10, 2008 | 01:53 AM
WHITE G5's Avatar
i got konis, but only the rear's
Old Apr 10, 2008 | 04:13 AM
HunterKiller89's Avatar
ouch...mine were like $7X0 shipped....and springs were like $220 (sportlines) $205 for a shop to install it all....so i have a $1200 suspension system
Old Apr 10, 2008 | 05:58 AM
bluebaltjim's Avatar
full stiff on the rear all the time, full stiff in the front for autox otherwise half way on the fronts. ive had them for 18000 miles and have not had any problems with them.
Old Apr 10, 2008 | 06:14 AM
RA080424's Avatar
Add me in, I've got Koni's and Sportlines; and THAT is total sex in the twisties.
Old Apr 10, 2008 | 09:01 AM
Dunkinuts's Avatar
pics?
Fallen33 you are added i will get you the sig banner tonight when i get off work.
how is the ride with them on full stiff on the rear? got pics of your konis?
Old Apr 10, 2008 | 01:20 PM
joeyblaze's Avatar
how much work goes into the cutting the front shocks apart? like would shops know how to do that..
