official pro kit thread
Old May 16, 2009 | 11:03 PM
09LTrider's Avatar
just got the pro kit on friday i'm gunna put it on this week. any body that has them should post pics or disscus how they ride i will have pics on this week
Old May 17, 2009 | 12:07 AM
Bumpin Balt's Avatar
Prokits are waste of time and money. Go low or go home! lol
Old May 17, 2009 | 10:06 AM
09LTrider's Avatar
yea thats what i hear... if i dont like it i can always go sportlines.. my buddy gave me a great deal and free install so i figured i would try em out.
Old May 17, 2009 | 11:03 AM
Nakaiya21's Avatar
Whoa...ok give your prokit a chance... I bought the SSC springs because the specs showed less drop than any other spring (for the ss/tc) and they advertised a ride that was nearly identical to stock... Well, when I put on the springs they ended up dropping the car more than spec (I am now at 1.5 gap front and 1.75 gap rear). The good thing is that the ride quality is still the same as stock (shouldn't be true but this is the case), but I did pick up some knocking between the rear sway bar and exhaust (because the car went so low). Now that everything is fixed and aligned the car seems to be running perfectly (no noticeable difference from stock) but I am glad I didn't get anything that would have resulted in a lower drop... I probably would have had to go back to the stock springs if that were the case...
Old May 17, 2009 | 11:58 AM
Stiner's Avatar
I cut mine down a bit...they arent quite as low as sportlines the ride is almost the same as stock as far as bumps etc but it handles noticably better. SO the car looks better cause of the drop but it doesnt ride like a buckle of bolts on bumpy roads and out handles stock easily.
Old May 17, 2009 | 02:06 PM
09LTrider's Avatar
I was tired of the 4x4 stance And I didn't want the ride of a dumptruck so that's why I went with the pro kit
Old May 17, 2009 | 04:10 PM
musifreak190's Avatar
same here 09LTRider
Old May 17, 2009 | 04:12 PM
cobaltltblue's Avatar
I still don't get it. the millions Gm spent getting that suspension to set records and you go and change it?
Old May 17, 2009 | 06:26 PM
09LTrider's Avatar
What records are you reffering to?
Old May 17, 2009 | 06:33 PM
BlackSSNick's Avatar
with sportlines it makes it better by haveing a stiffer spring rate
Old May 17, 2009 | 09:29 PM
The LT hasn't set any records! lol. The SS/TC is the only Cobalt with a decent factory suspension. LT suspensions are terrible. I have driven my mom's G5 and it is HORRIBLE! lol
Old May 17, 2009 | 11:27 PM
Nakaiya21's Avatar
Well I can tell that there will be some people out there that will chose not to believe but.......lowering the car has actually improved the handling. The ride is almost the same as stock (the car actually tracks a little better with the road) but there is now no body roll at all. The car sits absolutely flat now in the curves (the car actually has a slight body roll during cornering with the stock suspension)... the handling and response also seem to have improved.... I was also sitting on the fence for a while about lowering the car. The area I am in is not exactly meant for a lowered vehicle...but now that I have lowered Coby I am happy with the results...
06MetallicBalt
Jul 20, 2025 08:47 PM
dennis69
Oct 20, 2015 04:49 PM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
