Oh noes I haz shiny rotor!!!!!
Old Apr 12, 2011 | 01:40 AM
  #76
DiabeticKripple's Avatar
^ lol. And I happen to love my grandma, so why dint you stop being an inconsiderate *****? But no it's was with my gf. I don't get why ou keep insisting that they are different, when everyone else says they will work fine.
  #77
DOMDOTCOM's Avatar
MADE STANCE COOL
  #78
AndrewSS/TC's Avatar
Opinions anyone.....
Old Apr 12, 2011 | 01:43 AM
  #79
Marc_Mann's Avatar
I'm just saying I took them to a mechanic not a cobaltss.net certified mechanic and he said Im going to get some pull and the pads will wear differently.
  #80
Marc_Mann's Avatar
so glad I never bought any thing expensive from that company
Originally Posted by ls1fbody
omg, ARE YOU FKING SERIOUS?!?!?!
can you honeslty not tell the difference
Old Apr 12, 2011 | 01:44 AM
  #81
But they won't. Not bashing here. Within a few stops, the finish will be worn off and you will have 4 shiny rotors. When I got backfrom Hawaii I had alot o rust on mine, did a few panic stops and that shot was gone. Just put them on the car, and see if I'm, and everyone else here is wrong. If it pulls, just take them off, stop being a dick to zzp, and they will help you out. I still dont see why your turbo build has to be cancelled. Brakes are easy to do by yourself, and you will learn things while you do them. Get a few buddies, a case of beer and work on them
  #82
sundevil07's Avatar
omfg lmaoo!!!!
  #83
Old Apr 12, 2011 | 01:45 AM
  #84
DOMDOTCOM's Avatar
MADE STANCE COOL
  #85
Marc_Mann's Avatar
so my mechanic is on crack?
Old Apr 12, 2011 | 01:46 AM
  #86
ls1fbody's Avatar
Haz l33t wheelz.
Old Apr 12, 2011 | 01:47 AM
  #87
ls1fbody's Avatar
Haz l33t wheelz.
Im sorry, but the OP has to be the dumbest person i've ever run across on the internet.
Old Apr 12, 2011 | 01:48 AM
  #88
He might be......... You never know....... Just like you don't know who your father is......
  #89
I'm sorry but those will work perfect, after you install and hit the brakes once they will all match.
Old Apr 12, 2011 | 01:51 AM
  #90
thedude411's Avatar
Slam on the brakes once while you're doing your usual 260km/h driving speed and they will all look the same
Old Apr 12, 2011 | 01:52 AM
  #91
ronn's Avatar
Yeah..it's the surfaces that are coated on three of em..
I don't know why they are coated though..pointless...never heard of that.
Hats look all the same from what I can see.
Old Apr 12, 2011 | 01:54 AM
  #92
Perfect.disguise's Avatar
[IMG]http://i186.photobucket.com/albums/x126/dynopimp22092/e7fe685d.jpg[MG]
3 coated, 1 bare..4 of the same rotor
Old Apr 12, 2011 | 01:59 AM
  #93
SuperChargedMA's Avatar
Calls or emails zzp customer service...
"Subject: Order #????
Hi, I just ordered rotors from you guys and seeing as Im new to this, I was just wondering why one rotor seems to be different than all the rest. It's shiny, while the others seem to be coated. Im just wondering if there was a mixup or if this was just normal. Any help would be appreciated and thank you for your time."
You can copy and paste that if you want.
Old Apr 12, 2011 | 02:13 AM
  #94
ronn's Avatar
I have the answer HERE>>>
Found this:
Coated Zimmerman Brake Rotors/Discs from AutohausAZ - Benzworld.org - Mercedes-Benz Discussion Forum
I recently bought Zimmerman Coat-Z rear brake rotors/discs from AutohausAZ.
They are a horrible light grey/putty paint colour all over (apparently this is the "coat Z-Anti-Corrosion coating") and not like ordinary rotors which have a shiny 'steel' surface.
I absolutely hate the color!
Apparently, Zimmermann applies the Coat Z-AntiCorrosion coating to further improve longevity.
The installation instructions state that this coating should not be removed prior to usage.
What I want to know is will the rotors eventually turn into the desired usual shiny steel surface or will they stay this horrible colour?
__________________
The coating does wear away, it's a coating, not an alloy of some sort. The discs will shine up where the pads hit, but the zinc reduces the odds of it sticking to the hub and to the wheel and prevents corrosion elsewhere. I remember reading somewhere that it also hastens the bedding-in process, so all you need to do is drive normally and avoid abusing the brakes for a hundred miles or something like that, which is why they tell you not to clean it off, the pads will do it for you
Zimmerman Rotor:
Another Quote:
I happen to have installed a pair of these on the front of my daily driver/squadron hack (German by heritage but made in South Carolina) and followed the manufacturer's instructions to the letter-- after the first stop you can see the coating wearing off the wiped surface, after five stops its's gone. All you are left with is a thin gray wrinkly ribbon at the leading edge of the pads, which falls off in the airstream. It's almost like plastic. It doesn't embed in the pads or diminish braking performance (I haven't done a scientific test, however).
Old Apr 12, 2011 | 05:10 AM
  #95
Sweetsandman's Avatar
Epic
Old Apr 12, 2011 | 05:35 AM
  #96
cmatthewb101's Avatar
In for gangbang
Old Apr 12, 2011 | 05:47 AM
  #97
Garret's Avatar
this is funny, but not ha ha funny
Old Apr 12, 2011 | 09:23 AM
  #98
importkiller's Avatar
Good Lulz
Old Apr 12, 2011 | 09:28 AM
  #99
Wangspeed's Avatar
Originally Posted by ronn
Only one so far:
There's nothing wrong with the rotors in that picture. The one on the right should be in balance and have runout within specs. You'll probably see little flat spots on the circumference of the rotor for balancing purposes. For whatever reason, they didn't have to/want to run it through a lathe.
The one on the left was run through a lathe one last time. Maybe there was a little more run out than expected. Both should be just fine. After a few stops, you can't tell the difference between the two.
Marc_Mann, you are an idiot. You came in here blowing up a storm for this??? Go away.
Old Apr 12, 2011 | 09:43 AM
  #100
denlou's Avatar
Holy ****, the OP is retarded!
It's anti-corrosion coating, they put them on a lot of rotors so they don't get corroded and dont look rusty so dipshits like this guy will buy them. The one just doesn't have it for whatever reason.
Wow, just ******* wow...
There's no way a reputable mechanic ever told you anything to the contrary, you're so full of ****.
