OTTP Hardcore
Old Feb 9, 2010 | 07:18 PM
QuickShift's Avatar
OTTP Hardcore
In the spring Im looking to improve my handling without lowering my car...
Will I have alot better handling with the OTTP Hardcore Rear Bar and Eibach front with my otherwise stock FE3 suspension...
I know the Hardcore bar is serious but I have ESC to save me lol...
Old Feb 9, 2010 | 07:24 PM
Boosted_Cobalt09's Avatar
run the stock turbocharged sway bar up front.....the eibach i think is personally too big
Old Feb 9, 2010 | 10:19 PM
qwikredline's Avatar
QFT I agree
Old Feb 9, 2010 | 11:19 PM
northvibe's Avatar
I concur, stock front lnf bar, ottp hardcore bar in back.
Old Feb 9, 2010 | 11:26 PM
restonSS's Avatar
does the hardcore bar in the back really make that big a difference? im considering it but dont have a front sway.
Old Feb 9, 2010 | 11:30 PM
im sure you can find an lnf sway bar no issue. yes the bar makes a big difference.
Old Feb 10, 2010 | 10:38 AM
Terminator2's Avatar
I have the stock LNF front bar and the OTTP street rear bar and it does make a noticeable difference. The rear of the car wants to follow the front more now making the car more neutral with less understeer.
Old Feb 10, 2010 | 10:53 AM
northvibe's Avatar
I have the hardcore bar and you can tell its installed just by driving around town. I had it at a autox and if you arent careful you'll whip a 180 real quick. I'd say the hardcore bar is for people who autox or road course race, the street bar is for DD and everyone else. seriously.
Old Feb 10, 2010 | 11:30 AM
Illini_06SS's Avatar
Bigger front swaybar = Understeer
Bigger rear swaybar = Oversteer
The key is to find the sweet spot somewhere in the middle where the car is controllable but also agile, without too much of one or the other.
That's the setup I'm going with, but I'm keeping my FE3 bar on hand in case I have too much understeer with the bigger front bar.
Yes.
This. there's a reason why they call it "Hardcore" and the other is called "Street". It's not marketing, it's about the results that it will provide and the propriety for each one's use.
Last edited by Illini_06SS; Feb 10, 2010 at 11:30 AM. Reason: Automerged Doublepost
Old Feb 10, 2010 | 11:34 AM
recklessactn's Avatar
I have the hardcore and you can immediately feel the difference in the rear of the car, it's more responsive and cuts alot harder into the corners.
Old Feb 10, 2010 | 12:12 PM
northvibe's Avatar
yeah, I just see some "street" racers buying the hardcore bar then crashing their car on a clover leaf or some sweeping corner because they brake IN the corner...we dont ******* joke when we say its for real racing.
Old Feb 10, 2010 | 12:45 PM
Yes.
I do not think understeer will be an issue with the FE5 LNF front bar and the hardcore rear bar.
Old Feb 10, 2010 | 01:33 PM
nope it shouldnt be an issue.
Old Feb 10, 2010 | 05:06 PM
I agree. I can also say that when you install R100 slicks, you can be forgiven for thinking (as wel balanced and all that it is ) that just maybe, a tweensy eeny little more rear bar might be fun....like 1.50....but on street tires that would be sexiting....if not fatal and 10-4 on the lift and die mid corner
Old Feb 10, 2010 | 05:11 PM
lol never brake in the corner or else ur off... literally
Old Feb 10, 2010 | 05:57 PM
northvibe's Avatar
You'd be surprised what a "street racer" will do when they are coming in too hot into a corner if its a lnf, the word brembo on the brake can give a false sense of security as well
Old Feb 10, 2010 | 10:38 PM
lol brembo definately does give false hope sometime.
Old Feb 10, 2010 | 10:58 PM
blrt's Avatar
So what will happen if you have a set of CO with the hardcore bar? Will there be more oversteer or less in most cases when compared to stock suspension?
Old Feb 11, 2010 | 09:20 AM
the moment you say co I assume = coil overs, it depends on what you got for spring and damping rates. it is not any longer stock suspension...so impossible to say for sure. Need data....
Old Feb 11, 2010 | 11:43 AM
blrt's Avatar
Yes, coilovers. I have 353 lbs front and 224 rears springs. 20 ways adjustable damping but I am not sure what specs there are. I do have a set of 420 lbs springs for the front as well. I am not too concerned with having perfectly dailed in. Neutral balance would be ideal for my DD with the hardcore bar. Any suggestions John?
Thanks.
Old Feb 11, 2010 | 12:22 PM
Evoly's Avatar
I can vouch for mid corner lift = check your shorts with 1.25 and street tires lol.
I've said from get go, 1.25 for erious drivers only Great bars, I own both and no regrets thus far!
nathan112i
Sep 30, 2015 07:12 PM
umrdyldo
Sep 21, 2015 05:28 PM
