Pedders for 2009ss Question Bump Stops
Im on 235s with pedders and, to me, its the perfect combo. Cutting the stops isnt necessary unless you got coilovers like Stamina said. Personally, I slow down for any bump that I forsee causing an issue. I dont fly around going over stuff like if it wasnt there. I want my suspension to last. Oh, and I did install steering rack spacers to keep the steering rack aligned and not saggy.
Congrats on having the pedders installed OP!
First off I'm not going to use 235s no need to and they will slow you down acceleration wise. Second I KNOW those won't bottom enough to rub 235's . The pedders only dropped the rear about 3/4" and they're also STIFFER. BTW, the BEST way to solve that *problem*( if you have it?) is to get a wheel with the proper OFFSET which would move he tires INBOARD enough to escape rubbing against the fender lip.
and why did you make this thread if you cut them anyway?
Like I said, the springs are also STIFFER than stock (so they won't bottom as easily) and the Pedders only dropped the rear around 3/4" at most. Having said all this:
1) I won't use 235's 2) They won't work well on the stock 7.5" rim width anyway
You don't have them on THIS car. I can use CAPS too.
If you cut them on pedders what are you gonna do if you go lower take the bumpstops out completely?
but whatever it's your car have fun with it
Sorry if caps bothered you...not tryn to scream at you
I think he's saying that if I cut my Rear Bump stop (only 1/2" in my case), it would rub on bottoming. My argument is that 1) 1/2" more travel won't make a difference and 2) The Pedders are stiffer and that would *cancel out* that 1/2" of additional travel anyway.
your pedders will settle in about another 1/2" with time. (but you knew that) right
you asked for advice we were offering it, you did what you wanted. stop making threads like this then.
once you start making big power you'll know what me and HB are talking about but right now you still seem pretty giddy about 300whp.
all in time young grasshopper.......
Scroll half way down this link
http://www.ls1gto.com/forums/showthread.php?t=365443
and read this post>>>>
http://www.ls1gto.com/forums/showpos...3&postcount=17
I wound up cutting the first *ring* off the top in front (about 1/2") and the nub in the rear.
Better to do it now than have to go back in (in front). Some here advised not to cut, but I don't think 1/2" in front would be a problem at all. As far as the rear..I would find it hard to imagine hitting them even not cut with only 1" lowered, but taking the nub off is no big deal there either. The Pedders are being installed right now!
why cut any bump stops. im on sportlines, with a much softer spring rate, with no cut bumpstops. Ride isnt that bad. Now imagine sitting a little higher with a stiffer spring rate. jeezus itll be like a luxury car
Why did you bother making this thread? You just seem to be denying any advice that people are giving you and arguing with them that they are wrong.
People on here will very quickly just stop helping you if you have questions on your JUICED up car.
you could go out and get the poly bump stops from summit and put those in... thats what the s10 crowd does, it gives them about 3inched more travel at the wheels and still protects the car
Glad I'm not not only one that feels this way
After installation I found that the right rear is about 5/8" higher than the left
Any thoughts? I measured using several methods, so I know it's right.
Thanks..and I will be mindful to respect ALL opinions
I DO appreciate all the feed back and it was useful! I decided to take the advice of those who recomended to cut, but I only did that to a lesser degree. I fully respect those who had other opinions..really. Sorry if I offeneded anyone here. My appologies.
Any thoughts? I measured using several methods, so I know it's right.Thanks..and I will be mindful to respect ALL opinions
Dont cut bump stops. period. the end. Bump stops are there to protect the struts and shocks....regardless of what springs you have on the dtruts and shock only like to be compressed so far. I have NEVER cut bumpstops on ANY spring install Ive done any any Cobalt regardless of the spring. never had any complaints.
And as far as sitting weird.......
Ive had pedders on longer(beginning of '09) and probably gone more miles(25K+) as well than anyone on here and my car only has less than 1/4" difference side to side....(probably more like 1/8" when its not full of tools
Any theories as to why?
At first I thought the body work could be *off* (rear qtr panel tweaked?)..but I made other measurements too. 5/8" difference is a bit much..almost FU&&KN stock!
The rear drivers side seats higher on mine.
i think mavens the reason why i know to not listen to people and dont cut the bumpstops. it just makes sense. There that length for a reason for your shocks. Dont ****** cut em. end of story
You mean the plates...yes. I take it, if there was a problem there it would be uneven seating on the side that's higher up. I think I'm going to switch the springs for ***** and giggles.
