Pedders Installation Problem
I bought Pedders SportsRyder Springs from OTTP 2 weeks ago.
I drive a 07 SS/SC.
heres my problem:
the rear springs, the coil on the ends are too small to fit into the perch or that nipple thingy.
I've tried both top coil and bottom. no luck.
any insight? did ottp send me the wrong set?
I drive a 07 SS/SC.
heres my problem:
No, they did not. There are tons of threads around here about that. Some people file the springs (bad idea), some people heat them a little. I coated them with spray lithium grease and twisted the seat into the spring. It's not easy but they will eventually seat. You just have to work them.
Yea that's why I'm boy cotting Pedders, for 400 bucks you'd think they'd make
I'm a lil better, I had a set that the rear springs were 50 lbs difference between the 2 the powder coating
Was literally peeling off within a couple months of them being on the car, perches don't fit worth a damn,
Just stupid there making 400 on a set of springs ud think they'd be able to do a lil more r&d on um
But what ever
But what ever
But what ever
But what ever
But what ever
But what ever
I'm in the same boat. My rear springs were horribly wound at the end for springs this expensive. I ended up having to shave and heat, after failed attempts with lithium grease. I had to whack it in with a mallet while the mount was still hot. You'll want to stuff the springs with wood, otherwise hitting a spring with a heavy mallet will result in a regrettable story.
Grease alone wasn't anywhere even remotely going to work for me. The plastic seat would have cracked.
Wow holy ****...haven't heard anything about this before...god dam this pisses me off.
i've had so little luck with aftermarket parts, and this time i whip out the cash for something i thought would be good.....bam installation problems..
**** THIS.
**** THIS.
Ha. It's not a problem. It's a small challenge. VERY SMALL. I still did the rears in under 30min even with figuring out how to go about it. Shave the perch at the edge just a bit and then soak it all in wd40. Bam. Done.
Do you need a tampon or something? Man up and do work.
First, I want to thank a member of CobaltSS.net for making me aware of this thread. For those that don't know me my name is Pete Basica and I am President of Pedders USA. My office phone is 248.522.8021 email PGB@PeddersUSA.com I try to be as accessible as possible for our clients.
The Cobalt spring eyes are made to be as tight as they are to make certain they remain trapped when the vehicle is lifted or worst case airborne. This is required because of the rear shock extended length at full droop. There are two tips I can provide that will make rear coil installation smoother.
1. If you have a nice warm sunny day for your rear coil installation, let the OE plastic 'bake' in the sun. A more pliable plastic is easier to work with. If we don't have sun, a bucket of hot water will do. Heat guns can melt or burn the plastic so we try to avoid that or make certain great care is used with a heat gun.
2. Suspension work is sometime similar to another passion many of us share and is best when hot and wet ;-) Slippery is good. Liquid dish soap is a great temporary lubricant. When dry it is not slippery and it washes away with water. The warm plastic coated with liquid dish soap works well.
I am sorry for the frustration we have caused and will get these two installation tips posted on the website catalog and in our installation section.
Sincerely,
Peter G. Basica
Pedders USA, LLC
Sincerely,
Peter G. Basica
Pedders USA, LLC
Sincerely,
Peter G. Basica
Pedders USA, LLC
Sincerely,
Peter G. Basica
Pedders USA, LLC
Nice to see you here. A heat gun on the plastic lower half works well. Recent stock of Pedders shows an improvement, maybe its a tooling thing. The rear springs are smaller one end than the other fractionally so choosing through measurement works well + heat gun, + newer stock for whatever reason. The " dont want it to fall out when spring is extended"etc doesnt really play the top isolator falls out of the socket in the top of the frame if it is retained by the spring, and the issue is not the top isolator, its the black lower one. FYI....
Sincerely,
Peter G. Basica
Pedders USA, LLC
Sincerely,
Peter G. Basica
Pedders USA, LLC
but thanks for the feed back! glad you check forums!
