Pedders to yyz springs
Am I impressed with how the YYZ's have handled so far? yes, they are fantastic
what I'm not so pleased about is the fact that I have a whole new set of clunks/rattles that seem to have appeared since install when going over bumps, damn cobalt and its clunky suspension.... n everything is torqued properly so I'm at a loss as to why such a mild drop spring would cause these clunks to occur.. I have stock Fe5 shocks/struts, YYZ, and hardcore bar (if that even matters, it shouldnt)
When I changed my springs to my CMs it unsettled my sway bar end links, causing a sort of clunking noise up front when going over bumps. Seriously, sometimes those things get fucked up when you take them off / adjust them when they are seized on.
Mine has some rattles on rough roads mostly. The hats are right and lined up with the factory marks on the struts and point straight toward the engine. I already have powergrid endlinks. Could be LCA bushings but didnt have any noise till the springs went on. Its all tight/torqued and was double checked by shop when an alignment was done. I have a extra set of FE5 front struts with my TC's stock springs that I can reinstall to see if noise goes away.
front 26"
rear 27"
no alignment yet only put about 5 miles on them so far but they feel great!
alot nicer ride than the pedders and the koni yellow fronts definately help too
havent driven too much yet but the handling/response is awesome!
yup for sure and yup there awesome had the hankook rs3s before this but they are on backorder so i ordered these lol
Last edited by 09sscalicobalt; Oct 1, 2012 at 03:02 AM. Reason: Automerged Doublepost
wicked man nice ride as well, i seen the koni yellows lil intrested might be a gud sub to getting coilovers i doubt i would use them to the full potential, so i think maybe H&R springs since they give a lil lower drop and the koni yellows.
how long between when you did install and when you measured the fender height? I'm on pedders and with a hardcore bar and extremely happy with how it handles but if these YYZ springs are as bad ass as everyone says i may grab a set if they dont raise the car up. i was hoping the YYZ would end up about the same as Pedders up front and hair lower out back....
for those running the Koni yellows out back, which setting do you have them on?
the issue is simple, its important to have suspension travel to have handling. So there is a limit to how much lower it will be.
I'm considering getting Pedders and running them with my stock FE5 suspension (from what I understand, YYZ require Koni yellows pretty soon after installation. Are the Pedders still ok for everyday street spirited driving and occasional drag strip visits? And do you still carry those on your site? Thanks ahead.
