People with Pedders - ?
They will probably rub in the front I would guess, but its not going to be really bad. Probably only when you u-turn, or hit really large bump or pot hole. Just get 225/40/18. If you see a pic of an SS/SC in this thread its more than likely going to be that or 215/45/18 which looks the same.
resurrecting this thread back to life....
would 245/40/18's all the way around give any rubbing issues with FE5 TC struts/shocks with pedder springs?. i got 18x8's with 35mm offset. at the moment im running 235/40/18's but im just wondering if its possible to run 245/40/18's... the more rubber the better
it wont rub. i have the same size wheels with the same offset and 245-40-18's in the back. the fronts have 255 35 18. no rubbing unless i have a lot of weight in the car and i hit a bump.
