possible brenbo brake conversion
i have an 06 sssc n i want to get the brembo brakes that are on the new tc's and i was wondering if it would fit my spindles or would i have to get new ones. if so has anyone done this is it more hassle than it is worth. is there a better aftermarket option? if its as simple as getting the calipers n rotors boltin them on n go that would be great! thanks
Calipers, pads, rotors, pin kit, hoses, wheels that fit.
all true. the maven knows , but your sc wheels will need a spacer....or different wheels....
i know my stock wheels i just purshased rennen rc2 before the winter they are sitting in my garrage till spring salt is a bitch where i live will they clear the brembos do you know? the wheels ate the whole reason i wat the breaks the stockers look like ****!
I no my stock wheels wont fit*****
IIRC someone checked and said it took a 5/8" spacer to clear. Thats too much unless you upgrade your wheel studs.
you dont like pink? tell me what color you want so i can change it...
Last edited by qwikredline; Jan 26, 2009 at 09:29 PM. Reason: Automerged Doublepost
