Possible shock siezing?
Old Feb 16, 2010 | 09:35 PM
_UnLiMiTeD_'s Avatar
Quick back story, i got my sportlines installed a little while ago and the passenger side sat higher then the drivers side, did a few speed bumps and it went even with the drivers side.
So i didnt pay attention much anymore, lately though i notice its uneven again, same side. If i do more speed bumps and such, it sits even for another few days then goes back. Could one of the shocks be siezing up or worn out? I had the spring installation checked a few weeks back when i had the allignment done and everything is in properly.
Seeing as its one side sitting higher then the rest, its obviously not a sagging spring, so does a shock issue sound possible?
If someone else has another idea, please feel free to share as this one has stumped me
Last edited by _UnLiMiTeD_; Feb 16, 2010 at 09:35 PM. Reason: Automerged Doublepost
Old Feb 17, 2010 | 03:15 PM
Bump, can a partially siezed shock explain this?
so im the only one that thinks this is a plausible explanation?
Last edited by _UnLiMiTeD_; Feb 17, 2010 at 03:15 PM. Reason: Automerged Doublepost
Old Feb 17, 2010 | 10:31 PM
Quite surprised none of the experts here can't answer this one
Old Feb 18, 2010 | 01:33 PM
Old Feb 19, 2010 | 12:53 AM
Dave7417's Avatar
Damn, this site is a pain in the ass. I wrote a reply, but I guess I was too slow, and it kicked me off.
The long and short of my post was that you cannot determine a strut/shock seizing by ride height. I cannot be bothered to rewrite my post. Sorry, you should post in a quality forum!
Old Feb 19, 2010 | 10:04 AM
Well what else would cause one corner of the car to be higher then the rest?
Old Feb 19, 2010 | 09:31 PM
tru2nrtt777's Avatar
Honestly I am puzzled so I have no suggestions. Consider it a free bump.
What kind of springs? Sounds like there may be a defect in the spring IMO.
Old Feb 19, 2010 | 11:14 PM
eibach sportlines. Used for like 10k, i seen them on the previous owners car soon before they were taken off and they say fine
Old Feb 20, 2010 | 01:44 AM
Dave7417's Avatar
I over-cooked the Bilsteins on my rally car 30 years ago. The ride height was not affected. It just rode like a flat bed truck with no wheel travel.
Check for the usual visual things. Lift the rubber boot, and make sure there is no scoring/rubbing of the shaft. The strut may not be "seized" but is it bent?
ps(my post the other day was much more detailed, but I wanted to get this done quickly.)
Old Feb 21, 2010 | 08:18 PM
V8Rumble's Avatar
Is the tip of the spring riding up the bump in the perch? The one that you use to position the rotation of the spring.
Old Feb 21, 2010 | 09:12 PM
Well i had it back at the shop that did it and had it double checked at another shop and its all in fine. Also remember, it will sit proper, then one day it wont lol. I dunno, im lost with it, ill just have to not worry about it, it drives fine so
Old Feb 21, 2010 | 09:19 PM
qwikredline's Avatar
check the front lower control arm ball joint bushing etc for damage. check the rear twb the same for the pivot
check the shocks also
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
soaxin
Sep 26, 2015 08:41 PM
soaxin
Sep 26, 2015 08:39 PM
