Proper bleed/flush procedure for changing all four rotors/pads/brake lines?
Old May 29, 2009 | 12:42 PM
Johnboy12358's Avatar
Ok, I am getting ready to do a full brake job on all four corners on my car. I'll be replacing rotors, pads, and lines. When I do this, is it best to bleed the system after I replace each line, bleeding a total of four times?
Also, would it be a good idea to compress the pistons in the calipers with the bleeder open, before I replace the lines? Seems like that would evacuate some old fluid from the caliper, maybe save a couple of pumps of the brake pedal during the bleeding after install.
Old May 29, 2009 | 04:37 PM
tru2nrtt777's Avatar
Check the howto section, you should find your answers there.
Old May 31, 2009 | 10:26 PM
Found my answer here... one at a time:
https://www.cobaltss.net/forums/show...62#post1051462
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Delta coupe
Sep 30, 2015 08:11 AM
SlowSaturn
Sep 28, 2015 11:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
