question about brakes..
Old Sep 4, 2011 | 05:48 PM
RoryT_777's Avatar
hey guys i plan on doing pads and rotors here in a week or two and I'm join with r1 concepts dimpled/slotted rotors and hawk hps pads. my question is, do i need a press or puller to get the rotors off? or are they floating? i have an 06 ss/sc
Old Sep 4, 2011 | 06:01 PM
RoryT_777's Avatar
bump for enlightenment! come on lol
Old Sep 4, 2011 | 06:18 PM
uv blue's Avatar
you dont need a press or puller
Old Sep 4, 2011 | 06:20 PM
CTFinestTurbo's Avatar
no press just take your calipers off and the rotor should slip right off and if it doesnt use a hammer and hit the rotor couple times and the rotor should be able to come off.
Old Sep 4, 2011 | 06:30 PM
RooTBeeR's Avatar
1. pull off wheels
2. unbolt caliper
2.75. remove rotor locks
3. pull off rotor
4. new pads
5. rotor on
6. bolt caliper on
7. put wheel on
8. tighten lugs
Old Sep 4, 2011 | 06:31 PM
RoryT_777's Avatar
thanks guys! appreciate the help! good choice on parts??
Old Sep 4, 2011 | 07:16 PM
yea i run r1 drilled and slotted all the way around with hps hawk pads all the way around and i love em will install anything else!!
Old Sep 4, 2011 | 07:17 PM
RoryT_777's Avatar
ok cool! I'm not too sure about the drilled though. heard good and bad.
Old Sep 4, 2011 | 08:07 PM
Yea ive heard good and bad but i will see wut happens next year hopefully i wont have to do rotors on the car for atleast 2 yrs
Old Sep 4, 2011 | 08:42 PM
Sharkey's Avatar
i run r1 slotted/dimpled rotors and hawk pads, i love em. ive put 70k km on them and i need to get the rotors turned (starting to get a shake when braking) and the pads still look like new.
Old Sep 4, 2011 | 09:50 PM
I hope mine last that long
Old Sep 4, 2011 | 10:14 PM
You'll need a c clamp and a block (or the old pad) to press the cylinder on the caliper back, and pop your brake fluid cap loose when you do.
Old Sep 4, 2011 | 10:24 PM
Sharkey's Avatar
only do that with the fronts. the rear calipers must me screwed back in. you can do this with a set of needle nose pliers or get the tool for it.
Old Sep 4, 2011 | 10:30 PM
RooTBeeR's Avatar
this is the one that i bought
18 Piece Disc Brake Pad and Caliper Service Tool Kit
Old Sep 4, 2011 | 10:41 PM
you could go to like a carquest if you have one local and they have a little cube that has different style pins on each side of it that you could use and it would save u money cause if ur not a tech or do alot of brake jobs ur prolly never gunna need all of those attachments.
Old Sep 4, 2011 | 11:08 PM
RooTBeeR's Avatar
your right, I wont personally use them all haha but I have no problem letting friends/neighbors borrowing it. besides the whole kit was only $40 and it'll last a lifetime
Old Sep 4, 2011 | 11:11 PM
for $40 if thats all you paid its not a bad deal.
Old Sep 5, 2011 | 11:42 AM
Didnt know that, i'm a 2.2 so i have the wonderfully ugly drums back there... Hopefully not for much longer tho
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
