Question for ALL who have lowered SS S/C cars
Old Mar 3, 2008 | 11:24 PM
DoubleLP's Avatar
I had my lowering springs put on the other day and I am now experiencing the mystery "clunk" that seems to be quite normal for the Cobalt.
Has anyone tried replacing the front sway bar end links to get rid of the clunk?
I had the same clunk in my old Matrix after I lowered it and it turned out to be the sway bar end links that needed to be replaced.
I have a new set ordered from BWoody Performance and I should have them in a couple of weeks. I will keep everyone updated on what happens once they are installed!
Old Mar 3, 2008 | 11:34 PM
207GT04's Avatar
My buddy and I don't know of this clunk that you speak of? I never cut the front bump stops so sometimes that the only thing that normally clunks unless I am really missing something.
Old Mar 3, 2008 | 11:36 PM
DoubleLP's Avatar
It sounds like a front strut is blown. But it is actually the front sway bar end links that are loose. We found on on the passenger side of my car was loose, so I figure that the one on the driver's side is the same.
Old Mar 3, 2008 | 11:38 PM
95cam86roc's Avatar
I think the clunk that you speak of is coming from the stock struts... Mine does it too. The car has been lowered for a year now at about 18,xxx miles put on since the springs.
Old Mar 3, 2008 | 11:49 PM
DoubleLP's Avatar
Really? Wow that sucks. I am still going to replace the sway bar end links anyways since they are ordered and see if it makes a difference.
Old Mar 3, 2008 | 11:50 PM
95cam86roc's Avatar
Let me know if it makes a difference... but im almost 100% sure its the strut... Mine ONLY does it when its below 40deg outside.
Coblt ss super's Avatar
Mine does it on stock springs, but i think its becuase the deep potholes here in NY and it hits the bumpstops
Old Mar 3, 2008 | 11:59 PM
DoubleLP's Avatar
I have hit the bumpstops and that is a LOUD bang.....this sounds a lot more like a bad front strut.
Old Mar 4, 2008 | 12:02 AM
95cam86roc's Avatar
I think its bc the strut is completely compressed so your getting a dead end sound. Theres no fix for that w/a lowered car. There arent any aftermarket struts out yet for these cars.
Old Mar 4, 2008 | 12:03 AM
207GT04's Avatar
I still have not cut mine and trust me with the re-construction here in O-town I hit them atleast once a week. It sound like the friggin axle is coming through the car!
Yeah there are, Koni makes them but they are like 350 shipped for the fronts or backs only, so your looking at like 700 for struts
Old Mar 4, 2008 | 12:07 AM
95cam86roc's Avatar
We only have struts in the front so it would be $700.... I can put that money into something more worth while bc the noise doesn't get on my nerves enough to go blow $700.
Old Mar 4, 2008 | 12:11 AM
vtecduster's Avatar
My downpipe/cat was warped (dealer thinks due to winter and watershocking of hot metal). The warped DP was causing the cat to clank off of the front sway bar when the engine torqued back under throttle. Check the clearance on your DP/sway bar. Solved my problems. I really, really thought it was coming from one of the struts too..it was not. Give it a shot man.
Old Mar 4, 2008 | 12:16 AM
DoubleLP's Avatar
I will give a good look underneath the car when I replace them.
Thanks for the tips so far!! Keep them coming!!!
Old Mar 4, 2008 | 12:21 AM
CobaltSS 16's Avatar
what springs do you have?
Old Mar 4, 2008 | 12:24 AM
DoubleLP's Avatar
Ksport
http://www.ksportusa.com/asp/springs...roduct_id=sp01
Old Mar 14, 2008 | 07:08 AM
jerm's Avatar
Originally Posted by DoubleLP
How do you like those springs? I was looking at them as they claim it's not an extreme drop. Their website states 1/1.3 (front/rear) which is ideal to what I'm looking for.
Can you back up these claims? How is the ride with them? How long have you had them so far? Also, do you have any pics with them on the car?
Yes I know a lot of questions there... I appreciate any that you have answers for. Thanks!
Old Mar 14, 2008 | 09:34 AM
DoubleLP's Avatar
I really like the springs. Great ride quality, and a great looking drop as well and it is exactly what they claim. Unfortunately I do not have any pictures yet, but I will see if I can get some posted today.
Old Mar 14, 2008 | 09:53 AM
WhiteSSBalt's Avatar
Not a Sebring
My car has been lowered on Sportlines on the stock shocks/struts for almost all 41,000 miles I've driven the car. No telling how bad of shape my stock shocks/struts are in.... I know my camber is way off, and I'm ordering some SPC camber bolts and getting a full 4-wheel alignment this month though.
Old Mar 14, 2008 | 10:30 AM
jerm's Avatar
Awesome! Thanks DoubleLP!
Old Mar 14, 2008 | 10:56 AM
DoubleLP's Avatar
No worries!! I highly recommend buying them. And if you want a good deal...order them from www.neverenoughauto.com
Great price and fast delivery. They did not have any in stock when I ordered, so Ksport sent them from the factory directly to me. Great service!!
I am pretty sure it is not my stock struts that are causing the sound. I should be getting my new sway bar end links either today or next week, and I will get them on as soon as the weather permits!!
Old Mar 23, 2008 | 06:16 AM
DoubleLP's Avatar
UPDATE:
I finally received my new sway bar end links from Bwoody and put them in today. The "clunk" that I had is now completely GONE!!!!
So I highly recommend if anyone is having the exact same problem to change out your sway bar end links. It is easy to do (took me about 45 minutes total), and not that expensive either (around $100 US).
I did take a picture of the finished product....I just do not have access to photobucket here at work, so the picture posting will have to wait!!
Old Feb 10, 2009 | 01:32 AM
DARIN616's Avatar
I know this thread is old but i have the exact same problem and i need to get rid of it asap. Do you have a link to the sway bar end links that you used?
Old Feb 10, 2009 | 01:35 AM
ls1fbody's Avatar
Haz l33t wheelz.
powergridinc
great products, used on the Koni cars as well as the Time Attack Balt.
Old Feb 10, 2009 | 07:31 PM
MRZ - RedGTZ's Avatar
Arrow
We'll prolly get those sway bar end links done soon if we can get some interest for them.
The stock links really sucks...
GaryGibblez
Jan 14, 2020 10:35 AM
Turbo Johnny
Feb 21, 2019 09:41 AM
Haily229
Sep 17, 2015 07:18 AM
chris88z24
Sep 8, 2015 01:55 PM
