quick help before i order!
Old Apr 16, 2010 | 01:43 AM
brickloaf's Avatar
Im about to order a rear sway bar and I want to make sure that all I need to buy is the bar and thats it or do I need to order bushing/connectors etc etc... and any opinions on the sway bar I choose would be great
also will a TC FRONT sway bar work on a 07 LT?
Thanks!
Anyone??
Old Apr 16, 2010 | 03:22 AM
this-is-it-ss-05's Avatar
just go with eibach front and rear sway bar kit, you can't go wrong with them (unless you don't search and endup paying too much).
the set will have everything needed for installation or replacement.
Old Apr 16, 2010 | 03:30 AM
ls1fbody's Avatar
Haz l33t wheelz.
I'm going to add my input because i've seen you post about audio stuff along with Emp, and i always appreciate your knowledge, as i know nothing of audio.
TC front bar will work. You will need the dual bolt clamps and bushings. This is the front bar i recommend above all else. Just a perfect balance for the car.
Let me know if you have questions about the rear bar, or springs/shocks/etc.
Old Apr 16, 2010 | 03:41 AM
listen to him, he is my mentor. i don't know **** compared to him.
koch1ar's Avatar
Thanks!
Anyone??
ls1fbody he said it lulz
OTTP street rear bar is what u should get in back
https://www.cobaltss.net/forums/show...=205410&page=5
Old Apr 16, 2010 | 03:46 AM
brickloaf's Avatar
Alright thanks I appericate it..I'll shoot you a PM if I have any other questions cause Im like a suspension retard
Originally Posted by koch1ar
i think no. i thought 05-07 weren't swappable with 08-09. but i thought a read a post from maven that said, well idk im still kinda drunk, but thought i needed a ss/sc fe5 for my 09 LT. i've been very confused on the front sway bar. so much info pointing fingers the other way
Haha true this stuff confuses the hell out of me but doesn't the front sway bar just connect at the strut mounts right under the hood (basically a 5 min install)??
Old Apr 16, 2010 | 04:42 AM
I'm very sure you are drunk as hell. You are asking if the sway bar connects the struts????????? Reallyyyy??????????
boys with boys, girls with girls, strut mounts with STRUT BARS and sway bars to connect your left tire to your right tire in turns.
Old Apr 16, 2010 | 08:49 AM
brickloaf's Avatar
Damn chill out I thought strut/sway bars were basically the same thing...I'll prob just get the rear sway put in and leave it at that cause the front bar sounds like it would be difficult to install
Old Apr 16, 2010 | 09:45 AM
okay fine my bad, but i did said i think you were drunk :p
i can tell you this, if you can read a circuit diagram, then you can see a nut connected to a bar holding it and another bolt that need to be unbolted. sway bar and strut bar are the same, you replace one thing with another.
word of the day kids:REPLACE
you don't need to ADD just REPLACE. your only concern should be if you are strong enough to remove some bolts, example the bolts (with a spring) that connect the downpipe with the header or with the cat.
so buy both, do the rear is as simple as the front STRUT bar and look at the front, anyone here near you will help you since you are the guru in audio.
Old Apr 16, 2010 | 02:11 PM
koch1ar's Avatar
i think the ss/sc is direct swap while ss/tc you have to use ss/tc hardware
Old Apr 16, 2010 | 02:38 PM
wow this tc are really giving something to talk sbout. Didt kow that.
Old Apr 16, 2010 | 03:09 PM
koch1ar's Avatar
from Maven:
"In order to change an FE1 car over to an FE5 front antisway you must order 2005 SS/SC insulators, 2006-up FE3/5 cars use a "2 bolt" clamp and an insulator with a "hump" in it. ALL FE1 cars use a "1 bolt/1 slot" clamp, and insulators with "no hump" The 2005 SS/SC clamps/insulators are the only parts that allow a proper mod free install of an FE5 bar in an FE1 car."
https://www.cobaltss.net/forums/suspension-67/suspension-brake-facts-fe1-fe3-fe5-j41-jm4-jl9-137064/ its about half way down the page
Old Apr 16, 2010 | 04:08 PM
ls1fbody's Avatar
Haz l33t wheelz.
You should still use two bolt clamps. You will have to drill the second hole, but over time the added torsional forces will bend the single clamps and cause them to fail.
Old Apr 16, 2010 | 09:50 PM
brickloaf's Avatar
alright so heres what im going to order can someone look these over real quick to make sure its correct...
24mm SC sway bar
http://www.crateenginedepot.com/stor...P1661C188.aspx
2 of these insulators
http://www.crateenginedepot.com/stor...P1663C188.aspx
2 clamps
http://www.crateenginedepot.com/stor...P2578C188.aspx
thanks
Old Apr 16, 2010 | 10:20 PM
OBZ's Avatar
OBZ
For the record, the sway bar does connect to the struts.. Not directly but through the end links.. lol
24mm SC sway bar
2 clamps
thanks
Yep that is all you need. Just so you know you have to drop down the engine cradle to drill/tap for the 2bolt clamps.
Old Apr 17, 2010 | 01:29 AM
koch1ar's Avatar
24mm SC sway bar
2 clamps
thanks
wait! i thought only the tc bar needed clamps. looks like ur gettin a sc bar??
Old Apr 17, 2010 | 02:21 AM
brickloaf's Avatar
I want whichever one has a easier install cause either way it should be a drastic improvement
Old Apr 17, 2010 | 02:34 AM
for the tc or sc swaybar in your car. You need to drill. I'm sure you don't want to do that.
do eibach kit. It will bring everything needed for istallation and replace.
Old Apr 17, 2010 | 09:37 AM
OBZ's Avatar
OBZ
No you don't NEED to drill it for the 2 bolt clamp. It would just be better in the long run if you really corner your car. I am still on th 1bolt/1slot clamp and its holding up well with my ss/sc front bar. (although the racing season JUST started..) when i start having problems with these clamps i will take the time to drill and tap for 2 bolt clamps.
Why do you keep pushing the eibach kit? IMO the front bar is too big comparing to the rear on an LS/LT For an SS it would be better, because of the stiffer rear factory beam/bar
OP all you really need is the bar and 05 SS insulators. here is the GM Part # 22700091 I just went with moogs though..
Old Apr 17, 2010 | 01:19 PM
brickloaf's Avatar
Alright I'm ordering today but when you drill are you just drilling through sheet metal or what cause I'm not worried about drilling unless there's something important right behind the drilling surface
Old Apr 17, 2010 | 02:25 PM
ls1fbody's Avatar
Haz l33t wheelz.
It's pretty beefy material, but its the same as where the holes are on the SS's, so it won't compromise anything.
lol wtf?!
The Eibach bar is STIFFER
If the TC bar breaks the mounting points over time, how much faster do you think the Eibach one will take care of that???
Old Apr 17, 2010 | 03:10 PM
I'm pushing eibach cause I think they are replacement. Then again I'm not sure if the bar comes with bushing and clamps. Anyway energy suspension sales them.
Old Apr 17, 2010 | 03:13 PM
ls1fbody's Avatar
Haz l33t wheelz.
They fit in the stock location up front, but it is much much larger than the FE5 bar which is big enough.
Old Apr 17, 2010 | 08:08 PM
^^^^ anyway these are my thoughts, there is no way i'm against your word master.
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Slick_Nick
Sep 28, 2015 09:15 PM
ashalle2
Sep 27, 2015 03:28 PM
toledobalt
Sep 2, 2015 01:19 PM
