REALLY NEED HELP BY 2PM central
Old Apr 9, 2009 | 12:29 PM
no_mo_tires's Avatar
I have an 08 LT with sporlines
ok so my front drivers side spring keeps winding up when you turn the wheel and its going pop!!!!!! GM techs said they didnt know what to do about it and springs with progressive rate springs are notorious for this and they dont know what to do. What can I do about this? When I turn left and then turn it back it goes pop when I go left and then another pop when I go back , WTF????? please help!
ITS ONLY ON THE DRIVERS SIDE
anyone? I really need this solved today I am OCD about **** with my car being absolutely perfect.
bump #2
nump
Last edited by no_mo_tires; Apr 9, 2009 at 12:29 PM. Reason: Automerged Doublepost
Old Apr 9, 2009 | 01:39 PM
Maven's Avatar
It sounds like a problem with upper spring plate/bearing assembly.
The plate should be installed with the "tab" pointing IN toward engine bay. The bearing(white/yellow plastic disc) should be on top of that, and centered by the lip of the plate.
If the bearing is missing or damaged or improperly istalled youll get this issue, same if theres anything wrong with the upper seat.
The car comes with progressive springs stock so thats just your techs trying to BS about the springs.
Old Apr 9, 2009 | 03:32 PM
Bumpin Balt's Avatar
Yup. I would make sure the strut bearing is greased properly. That is likely the problem. I need to remember to re-grease mine when I re-install my lowering springs.
Old Apr 9, 2009 | 04:40 PM
qwikredline's Avatar
x 2 right on as usual thats why you get the big bucks
ThoR294
Oct 4, 2015 08:44 PM
camaromanss1992
Oct 1, 2015 10:51 PM
Joe09
Sep 18, 2015 09:22 AM
Redspire
Sep 16, 2015 07:08 AM
FLCobalt
May 19, 2006 11:44 PM
