Rear brake pads????
Old Oct 27, 2011 | 01:57 PM
superrslow's Avatar
Rear brake pads????
So my rear pads need replaced. The inside pad has been rattling around because it wasn't fitting in the groves on the piston. Autozone brings over all the pads they have and none of them fit in the groove. The dealer says only factory pads will fit the rear correctly.
Has anyone used power stop pads? Did they fit? And those of you that used the hawk pads. And did the job yourself. Did they fit properly into the two hole like slots on the piston? Does the rear end of your car rattle over bumps?
Old Oct 27, 2011 | 04:39 PM
NGASales's Avatar
We have sold hundreds of the rear turbo hawk pads and had zero issues
Old Oct 28, 2011 | 09:09 PM
BlackyK's Avatar
I have the Duralast Autozone pads on my rears. Slipped into the grooves perfectly. Judging by the rims in your sig, you have the SS/TC? Maybe the LSJ and LNF rear pads are (slightly) different, and he grabbed the LSJ pads.
Old Oct 28, 2011 | 09:24 PM
08SSTCRD's Avatar
The parts guys are probably getting you the LSJ pads, which are number 1044 I believe.
When the T/Cs first came out, all the major retailers listed the wrong rear pads.
The correct number for the rear of an '08+ T/C is 1095.
Old Nov 7, 2011 | 06:34 PM
superrslow's Avatar
hm, yeah ill check tomorrow and see, thanks guys,
cant believe only 3 people responded.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
