rear brakes
rear brakes
Ok guys I had my rear brakes replaced under warranty when they started scoring and stuff at about 15k miles. They replaced rear pads and rotors...At 30k same problem, but theyre arguing replacement
what should i do? What are a good alternative to the stock pads and rotors? I dont need drilled or slotted, then i would have to replace the front rotors cuz that would look stupid.
If you check one of the threads around about the SS/TC brakes, replace the rear rotors with the OEM stockers and pads with Hawk HPS. Perform a proper brake service to ensure the sliders don't bind up and you should be good from there.
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
