Rear hub asembly install
Old Oct 7, 2013 | 09:57 PM
Billdayton's Avatar
Exclamation Rear hub asembly install
I have a bad rear wheel bearing, and have ordered a hub assembly. Has anybody done this replacement, and have any tips? I see several "how-tos" for the front hub, but none for the rear.
Thanks!
Old Oct 7, 2013 | 10:09 PM
the rears are pretty easy compared to the fronts, the solid rear beam helps haha
make sure the e brake inst locked when u go to remove the caliper, have a tool or whatever your method is to press the piston on the caliper back in. give the brakes a few good pumps before u drive off
make sure to connect the sensor too haha
Old Oct 7, 2013 | 10:12 PM
andrewcarr1993's Avatar
Only thing you need is a deep well 15mm socket and you have to remove the rear springs.
Old Oct 7, 2013 | 10:21 PM
look on your cobalt . com for a how to
or just google it, there is a few out there
Old Oct 7, 2013 | 10:22 PM
Billdayton's Avatar
Remove rear springs??
Old Oct 7, 2013 | 10:35 PM
I had to to easily get at the bolts otherwise I wouldn't be able to get at them. Did it quite literally a week ago.
Removal of the rear spring is as easy as jacking up both rear wheels, unbolting the shock on each side and wiggling the springs loose.
Old Oct 7, 2013 | 10:45 PM
^ pretty much that haha
im on coilovers so the springs were easier to grab since they are shorter than the shocks
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
Sep 30, 2015 07:22 AM
Bohb
Sep 27, 2015 09:11 PM
