rear strut bar..??
Old Aug 31, 2009 | 09:43 AM
averagewhiteboy's Avatar
rear strut bar..??
Hey guys,
So, I was thinking yesterday.. Would a rear strut bar benefit these cars any? I know that no one makes one for the car, but I have a set of strut bars left over from my Dads Monte that I sized up and I could custom drill (even though I already have a front strut bar, I'd just use both the same ones) and use. Any ideas?
Thanks!
Old Aug 31, 2009 | 07:34 PM
Anyone have any idea..?
Old Aug 31, 2009 | 07:43 PM
yel-low's Avatar
i just put a rear sway bar on and it helped alot in the turns
Old Aug 31, 2009 | 07:44 PM
No, strut bar. lol. The strut bar is the high one.
Old Aug 31, 2009 | 09:15 PM
tru2nrtt777's Avatar
JBP makes one but I really dont see the point. We dont have rear struts or rear control arms.
Old Aug 31, 2009 | 09:25 PM
qwikredline's Avatar
agreed, the Cobalt race cars and Time Attack cars we built had a cross car beam front and rear, but the structure was gutted and the cage needed to replace the removed structure. You are best to leave the struts alone on a street car.
Last edited by qwikredline; Aug 31, 2009 at 09:26 PM. Reason: Automerged Doublepost
Old Aug 31, 2009 | 10:14 PM
^^^ We dont have rear struts... unless you have JBP coilovers.
Old Sep 1, 2009 | 08:59 AM
So, on our cars, it really won't do anything? I was under the impression that the stiffer the better?
Old Sep 1, 2009 | 10:04 AM
stiffer is always better(lol) but in this case the rear isnt doing much, the springs are well located elsewhere and supported, as someone pointed out there are seperate springs and shocks and no strut at the rear, and the shock bracket is well anchored in the structure...so no, not worth time/effort/money for no return...
Old Sep 1, 2009 | 10:07 AM
Gotya. I'm just so used to cars that have a normal suspension set up..
Old Sep 1, 2009 | 10:07 PM
QFT. I mean if you some how put enough twist in the chassis to move the spring mounts, shock mounts and torsion beam mounts then you may need some reinforcement but unless they come out with something worlds stickier than R-comps and somehow you dont flip while cornering that hard you arent going to move all those elements at once.
bigdeertz
Nov 17, 2016 09:41 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
