Rear Suspension Knocking
Old Sep 30, 2010 | 11:47 AM
Koepke's Avatar
hey guys, i just lowered my 08 cobalt ls on eibach sportlines and it looks great!
i had them on for a total of three days and had no problems, and couldnt complain about the ride quality at all actually.
yesterday someone rode in the back and ever since then i have been hearing a knocking seeming to come from my rear right shock. im not sure if it is the shock or not, it honestly sounds like theres a rock in my trunk rolling around in that right corner.
i hear the knocking only at very low speeds on any and every bump, small and big.
highway driving is completely normal, which leads me to believe that it isnt a failed shock.
ive been reading around and no one seems to have the same problem as me, so im posting a tread about it, i read about endlinks and several things, but honestly i dont even know what theyre talking about.
i have stock shocks and struts, and ive inspected them for leaking and cracks or anything, and they look fine, the sound is really bothering me and i want to nip it in the butt before anything serious happens, so if you could give me any input itd be great!
thanks ahead of time
-josh
Old Sep 30, 2010 | 11:54 AM
Jimmy SS's Avatar
Is the strut bolt torqued down?
Old Sep 30, 2010 | 12:01 PM
Wangspeed's Avatar
Do you have an aftermarket exhaust? If you do, part of it is probably banging either on the axle or one of the heat shields.
Old Sep 30, 2010 | 12:52 PM
Koepke's Avatar
No aftermarket exhaust, I actually read about that already and tried shaking my exhaust to replicate the noise, but no results. Plus it really seems like the sound is coming from the right rear and exhaust is left aligned. I did think about the shock bolt, I'll have to try to retorque it, any other ideas guys? I could spend hours describing the noise but it's mainly like a plastic rattle, driving me crazy hahah
Thanks again for replying
Old Oct 9, 2010 | 02:52 PM
395 plus's Avatar
If you have a camera the takes video put it under the car so you can see the suspension and then bounce the rear of the car and see if you can replicate the noise that way then watch the video to see if you see anything.
Old Oct 11, 2010 | 10:12 AM
Koepke's Avatar
Thanks you guys for replying, but i finally found it out hahaha
Loose shock bolt... im an idiot lol
I checked it and it had worked its way alllllllmost out, but i saved it, and have a way better ride!
Old Oct 30, 2010 | 10:16 PM
c4w18's Avatar
k which bolt is this because i have the SAME EXACT issue...i checked to see if the shock bolts were loose but maybe i overlooked something...my cars in the stealership right now for other **** and i asked them about it and they said oh its cause you have aftermarket struts/springs, but all of the other ones (front left front right rear left) don't make that annoying ass noise every time i pop over a bump. let me know when you can thanks!
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
