Rear sway bar without drop
I heard from someone on here that you shouldn't put in a sway bar unless your car is dropped. I believe it would still help right?
I want to put in a rear one and I have stock suspension otherwise. I don't plan on dropping my car at all.
1 Post
You don't need to be lowered for it to help significantly. My G5 is still at the stock height (I could probably nearly rock climb in the thing...), and the TTR rear sway bar turned the car into a go kart as far as handling goes.
im not dropped and run the TTR with no problems, who ever told that has no idea. The TTR works the same on a dropped car as does a stock ride height car. if anything you might feel more of dif ina stock car as the it will sway and roll more then a lowered car
thanks for all the info. I'll just have to see which one I want now. I'll probably get TTRs because they are a pretty involved vendor on here and G5Club.net
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
