Replaced brakes, have squeek now
Old Oct 22, 2012 | 10:56 PM
danpatmor's Avatar
Replaced my brake pads, as well as rotors about 2k miles ago, ever since replacement i get a high pitched constant squeek noise while driving. does not matter if brakes are in use or not. Only time the noise is not heard is when at a stop. It is rather annoying and i would like to get rid of it lol
pads i purchased incase that helps
Power Stop - Power Stop Brake Pad #PS-16
Old Oct 23, 2012 | 01:48 PM
Wangspeed's Avatar
Check to see if the backing plates or shims have slipped and are now in contact with the rotor. That, or a rock. I'd disassemble to check.
Old Oct 23, 2012 | 02:41 PM
AyrtonSenna's Avatar
Same thing happens to me, but only when I brake, once I swapped the brakes with R1 and HP+. Let me know where is yours coming from.
Old Oct 25, 2012 | 04:46 PM
danpatmor's Avatar
ok thanks, ill check em out this week to look for that, just got surgery a couple weeks ago so havent had a chance to work on the car yet lol
Old Oct 25, 2012 | 04:51 PM
OrngBalt's Avatar
Make sure your pads aren't in constant contact as well. They could be touching or rubbing even when not braking. Also, check as much of your brake lines as you can, I had an issue a couple years back with collapsed brake lines they were causing my pads to stay in contact with my rotors. It wore down my pads and warped my rotors.
Old Oct 25, 2012 | 05:42 PM
danpatmor's Avatar
i believe i may have constant contact. if thats the case what would i do to make that not happen? lol
Old Oct 25, 2012 | 05:47 PM
scagnetti76's Avatar
did you put anti seize on the caliper guide pins? If not, do that and check that you didnt damage, or mis-seat the o-ring around the caliper piston.
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
DANRICKARD
Oct 1, 2015 12:08 AM
