ride height compairison
Does or can anyone take pictures of an SS/SC on stock springs or measure the wheel gap it has. I"m going to buy the stock springs from the SS/SC to put on my SS2.4 and am just trying to visualize the difference it will make. I know it will be subtle but just curious. Based on my research the eibachs lower the ls models 1.6 inches front and 1.8 back (if memory serves me correctly) and on the SS/SC it only lowers it .5 inches in the back. That tells me there is about a 1.5 difference on the SS/SC than ls springs. Thanks
Depends on the type of Eibach Springs. I have a SS/SC and I'm looking at the Eibach Sportline Springs which will lower me 1" in the front and 1.3" in the back.
Check out this link
http://www.gravanatuning.com/applica...wering_Springs
Check out this link
thanks for the pics. To clear up my initial post. I was on eibachs website and the Pro-Kit for the SS/SC only lowers the car 0" in the front and 0.5" in the rear. The Pro-kit for the ls model lowers the front 1.6" and the rear 1.8". This is what leads me to believe that the stock SS/SC springs will lower the car about 1.6" in the front and 1.3" in the rear. Correct me if I'm wrong but the spring height on the LS is the same as the SS/NA right? In either case hopefully my intention now is more clear as I am looking to put stock SS/SC springs on my SS/NA and get a sublte but useful lowering. I'm also planning on the DC Sports STB and the progress anti-sway bar for the rear.
Originally Posted by j4s0nmuzik
Isn't this a myth because of the stock lip kit and larger rims of the SS.SC make it appear lower but in reality the springs are the same hieght. THere was a post about this a while ago. Do a search.
Edit:
I went on Chevrolet's website and looked at the SS/SC wheel and tire numbers, 215/45/18. compared to my 205/50/17. The SS/SC has an overall diameter of 25.6 inches where the SS/NA has an overall diameter is 25.1 inches. If the thread that talked about their ride heights being the same is true (not sure where it is right now) , then the springs of the SS/SC should be about a half inch lower to make up for the half inch increase in diameter on the wheels.
Did you install the SS/SC springs yet? I was looking at doing the same thing, but my research shows there would be no drop in the back eventhough GM specs show there should be a small drop. If you have done this, could you measure the distance from the center of the wheel to the edge of the wheel lip and post it? I had put this out of my mind until I came across this post, thanks!
Dennis
Dennis
you can look at my CARDOMAIN Page for ride height comparisons plus measurements provided. from this you can measure your own care to make your own informed decision. go to page 8
